Author Topic: Can't do a manual fsck on root system [SOLVED]  (Read 1201 times)
« on: September 21, 2021, 04:15:19 pm »
Lenovo B50-10 running Ubuntu 18.04
A mate sent me his Lenovo laptop to fix as it wouldn't boot and indicated a manual fsck was necessary.
It boots straight into the GRUB screen (without pressing the Shift key).  I selected "Advanced options for Ubuntu" and then selected "Recovery Mode" expecting to see another screen with a recovery mode menu so I could choose manual fsck, but it did an auto-fsck on /dev/sda2 and outputted two pages of stuff, exiting with Code 4 (which is just "File system errors left uncorrected").
Then followed the advice to run a manual fsck without the -a or -p options, finishing with "File system check of root file system failed.  Requires a manual fsck."
That it is performing fsck automatically at boot is making things difficult so I checked that the boot order is USB first then booted with an Ubuntu 20.04 USB in place with a view to running fsck from that - but this was ignored and it went into the usual routine.
I found the GRUB command line screen (typing c at one point) but none of the commands I could think of were recognised.
Any ideas, anyone?
EDIT 1:  Discovered that Legacy Boot was not enabled!  I can now boot from a USB and will be able to back up files before messing with the system.
« Last Edit: September 21, 2021, 09:47:23 pm by Keith »
Offline SeZo
Re: Can't do a manual fsck on root system
« Reply #1 on: September 21, 2021, 08:54:03 pm »
run fsck from a Live-CD/Live-USB
Identify partitions
sudo fdisk -l
Make sure they are unmounted:
for n in /dev/sda* ; do umount $n ; done
then run fsck on them (substitute X to suit):
fsck /dev/sdaX
or fix an hard drive related issue called bad blocks you may have (this will take a long time).
fsck -cy /dev/sdaX
fsck -C0 -p -f -v /dev/sdaX
« Reply #2 on: September 21, 2021, 09:47:00 pm »
Many thanks Sezo - that worked perfectly.
