Author Topic: 20.04 sees all my external drives as read only  (Read 562 times)
Offline diggsywiggsy
« on: November 10, 2021, 04:40:57 pm »
Hi my 20.04 has decided that all my external drives are read only which means I cant swap  files n folders.  How do I change this please....also my scrren goes off after 1 min I used to be able to extend the time via appearance in 16.04 but cant find how to do this on 20.04.  I am sure you guys have hidden it away somewhere....please help
cheers Diggsy
Re: 20.04 sees all my external drives as read only
« Reply #1 on: November 10, 2021, 07:38:18 pm »
Hi Diggsy - and welcome to the Forum.
You will find it very helpful to read the guide for new members: https://linuxforums.org.uk/index.php?board=209.0 where you will find information about the best way to post a topic.
In particular, you should provide as much information as you can about your system.  For example, what operating system are you using?  It looks like an Ubuntu-based OS, but might be Mint.
Assuming you are using Ubuntu, you can change the screen-blanking time by going to Settings/Power and changing the Blank Screen time.
As for your external drives:
1. You need to know your user ID (uid) - if you are the only user of your computer the user ID will almost certainly be 1000 but you can check by starting a terminal session and entering the following command:
uid
2. Now you need the path to your external drive.  enter the following code:
df | grep media
and look for something like /media/diggsy/device-name.  A random USB drive of mine says "/media/keith/USB1G".  At the start of that line you will see something like /dev/sdb1.  Copy this phrase.
3. Having found your uid and /dev name, enter the following code:
sudo mount -o remount,uid=1000,gid=46,rw /dev/sdb1
inserting the appropriate uid and /dev name.
This should allow you to access the device.
Please let us know the outcome.
