Author Topic: WordPress: Theme TT2 (twenty-twenty-two). - getting it and get familiar with FSE  (Read 464 times)
Offline rincon
hello dear community here in this great forum - in LinuxForums,
i have heard alot about the new Full Site Editing (FSE) and Block Theming:
The new FSE should get in effect in the Theme TT2 (twenty-twenty-two).  i want to get familiar with the new theme as soon as possible?
that said:
- can i fetch the theme TT2 and install it in the WP 5.8.2 ?
- can i play with the FSE and get familiar with the new theme-technique!?
i have heard that best method to install TT2 is while using something like localwp,
if doing so i guess that i might  open a terminal and then should navigate to the themes folder
and clone the theme repo from Github with git
 another method could be to try this plugin: https://wordpress.org/plugins/wordpress-beta-tester/
The latest update is the 5.9 beta I think. So i guess, that i install the Version 5.9 and will try to test with the TT2 Theme.
what do you say?! Look forward to hear from you
regards
