Author Topic: Need to update Chrome browser on my Peppermint Netbook  (Read 227 times)
Offline Matilda
  • Gender: Female
« on: December 30, 2021, 01:09:48 am »
Chrome browser is out of date and very very slow. How do I update it guys?
Got 2 Linux computers:
Peppermint on a netbook
Ubuntu on a Macbook Pro
Also got a Chromebook!
Re: Need to update Chrome browser on my Peppermint Netbook
« Reply #1 on: December 30, 2021, 03:48:11 pm »
HI Matilda.
Is this on your MacBook?
Offline Matilda
  • Gender: Female
« Reply #2 on: December 30, 2021, 10:59:38 pm »
HI Matilda.
No, the Peppermint Netbook ( as I wrote in the title--  ;) ).
Usually there is a shield icon thing to enable updates- it gives notifications but does not work this time.
« Reply #3 on: December 31, 2021, 03:44:46 pm »
If your computer update repositories are set up with one for Chrome then this should work:
sudo apt update
sudo apt upgrade
(It will update everything).
If that doesn't work, then re-install Chrome as in your other post.
Offline Matilda
  • Gender: Female
« Reply #4 on: January 01, 2022, 02:03:04 am »
I will try that over the weekend. I tend to mostly use the netbook for scanning, which I will be doing then. I would use it more if it were faster ( it hasn't got an SSD drive).
