Author Topic: Installing 2nd hard drive in existing linux computer [SOLVED]  (Read 382 times)
Offline emp1953
« on: January 11, 2022, 06:23:49 pm »
I have installed a 2nd SATA 500Gb hard drive in my existing Fedora 19 computer.  How do I get the OS of recognize and use this new HD?
Thank You all for any help
« Last Edit: January 14, 2022, 03:03:19 pm by emp1953 »
Re: Installing 2nd hard drive in existing linux computer
« Reply #1 on: January 11, 2022, 06:39:18 pm »
Hi Emp53 - and welcome to the Forum.
Once the new HDD is attached, it should appear listed in your file manager.
I am not familiar with Fedora but if it works anything like Ubuntu, you can also check with the following command:
 df | grep "/dev/sd"
This should list drives sda1 and sdb1
By the way; is the new HDD external or internal?
Offline emp1953
« Reply #2 on: January 11, 2022, 06:41:24 pm »
It is internal installed on the SATA3 connector on the motherboard.  Seagate New in box.
Offline emp1953
« Reply #3 on: January 11, 2022, 06:42:57 pm »
The results of that ls | grep command only show sda1.  nothing else.
Offline emp1953
« Reply #4 on: January 11, 2022, 06:50:19 pm »
Under activities there is a "disks" utility that is a gui representation of whats in the system.  This utility shows two 500Gb seagate hard drives,  the first one listed as the master boot record and is the one that I assume I boot from and contains my Fedora OS.  its device Id is /dev/sda1 and shows a mounting location
The second device Id is /dev/sdb  this does not show a mounting location.   If it is /dev/sdb then do I simply need to mount the device, if so, where should I mount it?
Offline emp1953
« Reply #5 on: January 11, 2022, 06:53:06 pm »
By the way the HD box does not say whether it is formatted.
« Reply #6 on: January 11, 2022, 07:07:05 pm »
1. First of all, please copy and paste the output from the df command that you entered so that we can see what's happening.
2.
I presume you mean the box it came in.  But it will be formatted.
Offline emp1953
« Reply #7 on: January 11, 2022, 07:08:49 pm »
output from "fdisk -l"
[email protected] ~]# fdisk -l
Disk /dev/sda: 500.1 GB, 500107862016 bytes, 976773168 sectors
Disk label type: dos
Disk identifier: 0x000510f7
/dev/sda1   *        2048     1026047      512000   83  Linux
/dev/sda2         1026048   976773119   487873536   8e  Linux LVM
Disk /dev/sdb: 500.1 GB, 500107862016 bytes, 976773168 sectors
Disk /dev/mapper/fedora_new--host--7-swap: 4177 MB, 4177526784 bytes,
8159232 sectors
Disk /dev/mapper/fedora_new--host--7-root: 53.7 GB, 53687091200 bytes,
104857600 sectors
Disk /dev/mapper/fedora_new--host--7-home: 441.7 GB, 441714737152
bytes, 862724096 sectors
« Reply #8 on: January 11, 2022, 07:40:08 pm »
This looks good.
Now please execute my suggestion:
 df | grep "/dev/sd"
and post the output here. It's best to copy the output and paste it here, rather than just typing it.
Offline emp1953
« Reply #9 on: January 11, 2022, 08:46:52 pm »
[email protected] ~]# df | grep "/dev/sd"
/dev/sda1                               487652    103222    354734  23% /boot
« Reply #10 on: January 11, 2022, 08:58:25 pm »
That's interesting:  fdisk recognises the new disk but df doesn't.
I don't have any ideas at present, but will have a think.  Perhaps another Member can help.
Offline emp1953
« Reply #11 on: January 11, 2022, 09:00:26 pm »
Does it need to be mounted?
« Reply #12 on: January 12, 2022, 09:43:31 am »
It does indeed.
First of all, try
mount | grep "/dev/sd"
to check if it's mounted somewhere unexpected.
Offline SeZo
« Reply #13 on: January 12, 2022, 10:31:52 am »
It looks to me that dev/sdb is not partitioned:
Missing the partition data
« Reply #14 on: January 12, 2022, 11:19:31 am »
The fdisk -l command doesn't list partitions, I think.  It didn't list your sda partitions.
Please execute
and report the full result.
