Author Topic: Installing 2nd hard drive in existing linux computer [SOLVED]  (Read 407 times)
Offline SeZo
Re: Installing 2nd hard drive in existing linux computer
« Reply #15 on: January 12, 2022, 12:22:06 pm »
the fdisk -l does list partitions:
Disk /dev/sda: 500.1 GB, 500107862016 bytes, 976773168 sectors
Disk label type: dos
Disk identifier: 0x000510f7
/dev/sda1   *        2048     1026047      512000   83  Linux
/dev/sda2         1026048   976773119   487873536   8e  Linux LVM
but listed none of them for /dev/sdb
« Reply #16 on: January 12, 2022, 12:25:12 pm »
It does indeed with the "long" option.
Please try
mount | grep "/dev/sd"
and post the whole output.
Offline emp1953
« Reply #17 on: January 12, 2022, 02:38:48 pm »
[[email protected] home]# mount | grep "/dev/sd"
/dev/sda1 on /boot type ext4 (rw,relatime,seclabel,data=ordered)
« Reply #18 on: January 12, 2022, 02:47:20 pm »
Sezo - Sorry, I missed your name on your posts.
Neither fdisk -l nor df list sdb on Emp's computer so I can't see how to create partitions unless the drive can be seen.  If you can advise him, please jump in and take over.
Offline emp1953
« Reply #19 on: January 12, 2022, 03:37:44 pm »
Assuming the new HD came formatted is it also safe to assume that it is NTFS  ?
« Reply #20 on: January 12, 2022, 05:31:12 pm »
Probably, yes, but Linux will cope with that.  One can use fdisk to specify a range of formats, all of which Linux can use.
Offline emp1953
« Reply #21 on: January 12, 2022, 06:08:31 pm »
Are there any BIOS settings that need to be changed so the HD is seen upon boot up?
« Reply #22 on: January 12, 2022, 06:12:44 pm »
No, I think not.  One can select the boot order, and it might be interesting to boot into the BIOS to see if your new disk is listed as an optional HDD to boot from.
Offline emp1953
« Reply #23 on: January 12, 2022, 06:53:18 pm »
Nothing on any of the listings I've done shows that it has a boot sector?
Offline SeZo
« Reply #24 on: January 12, 2022, 08:05:32 pm »
Not familiar with fedora so please forgive my ignorance if this does not work as intended.
The problem appears to be that the HDD (/dev/sdb) appears to be un-partitioned.
Therefore there are no mountable partitions.
You could install parted:
sudo yum install parted -y
Then list the available
sudo fdisk -l
(make sure /dev/sdb is listed)
Then run parted:
sudo parted -a optimal /dev/sdb
Note you will stay in parted shell, shown as (parted)
print out the current HDD configuraion
(parted) print
This should give you the list of partitions (I assume will be none)
To create a standard dos partition table (use gpt if you prefer GPT):
(parted) mklabel msdos
(parted) print
Create one primary partition as ext4
(you still need to create the filesystem, see later)
(parted) mkpart primary ext4 0% 95%
(parted) print
A new partition should be listed
then exit
(parted) q
Now create the filesystem
sudo mkfs.ext4 /dev/sdb1
Note, you can create ntfs instead of ext4 if you like.
After that it will get automounted (probably)
« Reply #25 on: January 12, 2022, 08:19:31 pm »
Many thanks, Sezo.
Offline emp1953
« Reply #26 on: January 13, 2022, 01:05:46 am »
Apparently "parted" is not in my repository. googled how to get it and install it, suggestions using dnf and git.  Also not in my distro.  I feel like a rat in a maze, with no cheese.
Offline SeZo
« Reply #27 on: January 13, 2022, 10:08:24 am »
Surprised that parted is not in the repo for your distro, it is Fedora you are using?
According to this : https://docs.fedoraproject.org/en-US/Fedora/14/html/Storage_Administration_Guide/s1-disk-storage-parted.html
By default, the parted package is included when installing Fedora.
Have you got Gparted installed?
Offline emp1953
« Reply #28 on: January 13, 2022, 04:49:05 pm »
Gparted was not part of my Fedora 19 installation either it is not in the repo.
Offline emp1953
« Reply #29 on: January 13, 2022, 07:03:38 pm »
My system has an app called "gdisk" when when entered at the cmd line returns "GPT fdisk (gdisk) version 0.8.18
