Website
Home
Forum
Help
Search
Calendar
Media
Blog
Login
Register
Support
Netbooks
3g dongle and linux os netbook
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: 3g dongle and linux os netbook (Read 15806 times)
lostone
Jr. Member
Gender:
What light? I'm still looking for the tunnel!
Re: 3g dongle and linux os netbook
Reply #15 on:
July 05, 2010, 10:42:20 am »
In reply too your enquiry about "keyring" passwaords....well of course I put one in
....and now I cannot find out how to remove/change it
I will be back after I have clean installed and got as far as your last post...without all my mistakes and in the right order....
he he
...sorry just made me think of Eric Morecombe and Andre Previn, but I expect your too young too know who I'm on about.
Logged
The obscure we see eventually. The completely obvious, it seems, takes longer.
Mark Greaves (PCNetSpec)
Hero Member
Gender:
"-rw-rw-rw-" .. The Number Of The Beast
Reply #16 on:
July 05, 2010, 11:30:49 am »
I remember it well... Eric Morcombe and "Andrew Preview"... I'm playing all the right notes, but not necessarily in the right order.
Unfortunately I'm not as young as you think
If you delete all entries under the "Mobile Broadband" tab, this will clear ALL setting for the dongle (including keyring password) and then you can enter them again.
Last Edit: July 05, 2010, 11:32:35 am by Mark Greaves (PCNetSpec)
Logged
WARNING
: You are logged into reality as 'root'
Reply #16 on:
lostone
Jr. Member
Gender:
Reply #17 on:
July 05, 2010, 11:53:30 am »
When this B***D* dongle connects I will lend you my zimmer frame and race you to the PUB
Right I have opened a terminal...am I supposed to see a joke and a (I think it is) cow???
Now I am not sure about this so be patient...do I type in "Code:[select]1susb" (without quotes)...i know this is old hat for you but my computing started after the Dos time and it was what kept me from Linux in the first place as I do not have a clue when it comes to Dos
Logged
Hero Member
Gender:
Reply #18 on:
July 05, 2010, 12:14:56 pm »
No...just the stuff between the grey lines, and that isn't a 1 it's a small L... so it's LSUSB but in lower case, it MUST be in lower case as Linux commands are case sensitive.
you won't find DOS here... BASH, ZSH etc. but not DOS
Nearly all of this stuff CAN be done in the GUI, but it's easier for someone at the forum to give you CLI commands... takes less typing, and I'm lazy be nature
Really it's because there is less room for misinterpretation.
Last Edit: July 05, 2010, 12:28:03 pm by Mark Greaves (PCNetSpec)
Logged
WARNING
lostone
Jr. Member
Gender:
Reply #19 on:
July 05, 2010, 12:25:41 pm »
Right a bit of a delay as this silly touch pad is really annoying...so have found mini mouse (no not Mickey's friend, a mini mouse)
So I have a list ... so what is it I am looking for??
Logged
Reply #19 on:
Hero Member
Gender:
Reply #20 on:
July 05, 2010, 12:29:35 pm »
I just wanted you to post the list, so I can check the dongle has been switched from ZeroCD mode to 3g dongle mode.
I was going to google the device ID's
Logged
WARNING
lostone
Jr. Member
Gender:
Reply #21 on:
July 05, 2010, 12:50:57 pm »
I was afraid this would happen
...I have'nt a clue how... as I am using my desktop to post here ... I have not tried to logon with the netbook yet
Oh well here goes...
Logged
Hero Member
Gender:
Reply #22 on:
July 05, 2010, 12:54:54 pm »
If there is a line with
Huawei
in it... and just send me that line
you can ignore any lines that end in
root hub
if that helps
Logged
WARNING
lostone
Jr. Member
Gender:
Reply #23 on:
July 05, 2010, 01:05:49 pm »
how do you copy/paste from the terminal ... I am now using the netbook...so I thought I could just copy/paste
Logged
Reply #23 on:
Hero Member
Gender:
Reply #24 on:
July 05, 2010, 01:10:17 pm »
same way as normal... use your mouse/touchpad to highlight want you want to copy, and right-click>copy.....
Last Edit: July 05, 2010, 01:17:35 pm by Mark Greaves (PCNetSpec)
Logged
WARNING
lostone
Jr. Member
Gender:
Reply #25 on:
July 05, 2010, 01:19:21 pm »
Bus 002 Device 002: ID 093a:2500 Pixart Imaging, Inc. USB Optical Mouse
Bus 001 Device 004: ID 19d2:0103 ONDA Communication S.p.A.
Bus 001 Device 003: ID 0c45:62c0 Microdia Sonix USB 2.0 Camera
just a thought the dongle is not a Huawei it is a zte mf112... i am still looking it up on google
Logged
lostone
Jr. Member
Gender:
Reply #26 on:
July 05, 2010, 01:34:48 pm »
OK have found that Huawei make the ZTE MF112...so disregard last line of previous post
Logged
Hero Member
Gender:
Reply #27 on:
July 05, 2010, 01:39:11 pm »
OK, I've found what the problem is... the device is VERY new so the device ID strings haven't been added to usb-modeswitch yet.
There are workarounds, but I'm going to have to do a bit of research first... if you want to check back this evening I'll have a solution for you.
this line -
tells me the device hasn't been switched out of ZeroCD mode... if it had, it would have changed to -
Bus 001 Device 00x: ID 19d2:
0031
ONDA Communication S.p.A. ZTE MFxxx
you could try typing this into a terminal:
Code:
[Select]
eject
and then:
Code:
[Select]
lsusb
again to see if it changes.
If not let me know, then check back this evening
Logged
WARNING
lostone
Jr. Member
Gender:
Reply #28 on:
July 05, 2010, 01:48:33 pm »
No change...will check back later, as I have two dogs standing here with their legs crossed
Logged
Hero Member
Gender:
Reply #29 on:
July 05, 2010, 01:50:03 pm »
At least the device ID strings hadn't been added to usb-modeswitch as of late May 2010... but things move pretty fast in the Linux world, so if you run an update of Mint it might "just work".
to update Mint... click the
padlock
icon by your clock, enter your root password, and when the updater loads... click
Edit>Preferences
... in the "
Levels
" tab, put a tick in the "
Visible?
" box for Level 5, and click "
Apply
Now, back in the Update Manager... click "
Select All
", and then "
Install Updates
The reason I said to enable level 5 updates... to update the kernel, as there is a known switching issue for ZTE dongles in kernels 2.6.26 -> 2.6.28
This will update you to kernel 2.6.31
If you want to know which kernel version you currently have installed... open a terminal and type:
Code:
[Select]
uname -r
Last Edit: July 05, 2010, 03:22:25 pm by Mark Greaves (PCNetSpec)
Logged
WARNING
Print
Pages:
1
2
3
Go Up
« previous
next »
Support
Netbooks
