Author Topic: Dazzel DVC 100 Program Help?  (Read 2853 times)
Offline BkS
  • BkS Media Founder
« on: July 12, 2010, 01:00:33 am »
is there any software i can use with my Dazzel DVC 100?
Re: Dazzel DVC 100 Program Help?
« Reply #1 on: July 12, 2010, 01:58:17 am »
Try installing dvr from synaptic
sudo apt-get update && sudo apt-get install dvr
now (with the dazzle plugged in) from the terminal type:
dvr-qtgui
From what I can tell a dazzle operates as a video4linux device (webcam etc.) so any application that can record from a video4linux device should work, such as -
camorama
cheese
or even better
vlc
all of which can be installed through synaptic
« Last Edit: July 12, 2010, 02:08:06 am by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
« Reply #2 on: July 15, 2010, 01:35:32 am »
thanks for that mark :).
