Author Topic: Final choice of Linux  (Read 1532 times)
Offline Kenny
« on: July 14, 2010, 08:11:43 am »
I have more or less decided on the final choice of Linux to install on my hard drive.Couple of questions though.When I install it onto my hard disk,how easy would it be to install a different version,or even uninstall it completely if I wanted to? Now as we all know,Windows uses a registry;does Linux use one,or something similar? My last point is about the amount of space to allocate for the install,or is that done auromatically? Thanks in advance for any help  :) Kenny
I should have mentioned the Linux I am considering is Linux XFCE
« Last Edit: July 14, 2010, 08:19:24 am by Kenny »
Re: Final choice of Linux
« Reply #1 on: July 14, 2010, 12:13:14 pm »
As your asking about allocation, I'm guessing your going for a dual-boot setup on a single drive.
Changing the distro will be a fair bit easier if you create a separate partition for your user files and mount it as /home and don't encrypt it.
Complete uninstallation should be easy enough, just use a Gparted LiveCD to delete the Linux partitions and resize the Windows one (if needed)... but you would also need to reinstall the Windows bootloader, fairly easy if you have the Windows installation disk.
GOD NO... Linux doesn't use anything as arcane as the Windows registry.
If you are installing to a drive that already has Windows installed, resizing and partitioning won't be done automatically, as you are going to have to resize you windows partition first... but this can be done from inside the Linux installer.
(I've also found it best to run a defrag from inside Windows before resizing the partition)
Allocation... most people say a minimum of 10gb, but it depends on what you are going to be using it for, I'd say if you have room give it 30gb (ish)...
10gb mounted as /
twice your RAM as Swap
and the rest (18gb ish) mounted as /home
XFCE is a Linux desktop, not a distro... do you mean Linux Mint XFCE, Xubuntu, or similar?
be aware that although XFCE will run slightly faster than Gnome or KDE on older hardware, you may find support somewhat harder to come by as less people use it, but the choice is yours :)
« Last Edit: July 14, 2010, 12:41:26 pm by Mark Greaves (PCNetSpec) »
