Author Topic: new to *linux  (Read 7550 times)
Offline jmyeom
new to *linux
« on: July 23, 2010, 04:55:01 am »
hi, i need some help
all my life ive using windows, i know it inside and out, i know every little detail about it,
but, its not doing it for me on a netbook,
so, i really am new to it, never used one, but planning to install on my netbook
i got this netbook for £50, its the acer aspire one, after a good clean and added 1gb of ram, im ready to go
but i dont have a clue about linux, im a php coder, so i need notepad and some kind of local host, (im guessing lampp?)
i have some memory sticks and some other stuff, now would i go about installing linux and running it, and what would you say the best linux build is?
Offline Mad Penguin
    • Linux in the UK
Re: new to *linux
« Reply #1 on: July 23, 2010, 08:49:28 am »
Ok, try this page out for a start; https://help.ubuntu.com/community/AspireOne
Which Distro is "best" is always debatable, however which distro will provide you with the most / best support is becoming a little more clear cut ..  :)
Re: new to *linux
« Reply #2 on: July 23, 2010, 10:06:25 am »
You will find help/support much easier to come by for either Ubuntu, Ubuntu Netbook Edition, or Linux Mint.
At the moment we are suggesting that people should stick to Ubuntu 9.10 (karmic) or Linux Mint 8 (Helena)... rather than use the latest Ubuntu 10.04 or Mint 9... at least until the known issues have been ironed out.
Ubuntu 9.10 (karmic) 32bit ISO
Ubuntu 9.10 (karmic) Netbook Remix ISO
Linux Mint 8 (Helena) Main Edition ISO
Download the ISO image of whichever distribution you decide to go with from one of the links above, and then for ease of installation follow the instructions on one of these pages to create a LiveUSB stick for installation/testing.
http://www.pendrivelinux.com/create-a-ubuntu-9-10-live-usb-in-windows/
http://www.pendrivelinux.com/usb-ubuntu-netbook-remix-install/
http://www.pendrivelinux.com/install-linux-mint-8-to-a-flash-drive-in-windows/
And just in case you want a tutorial on installing LAMP in Ubuntu/Mint (Mint 8 is based on Ubuntu 9.10, so any help/tutorials will work for both):
http://tuxtweaks.com/2009/10/install-lamp-on-ubuntu-9-10-karmic-koala/
If you *must* have notepad, install WINE, it comes with notepad, but you would be better off with gedit (default text editor in Ubuntu and Mint) or any number of other Linux text editors:
Linux Alternatives to Windows Software
« Last Edit: July 23, 2010, 01:20:31 pm by Mark Greaves (PCNetSpec) »
Offline Jayne
    • Edgley Forums
Re: new to *linux
« Reply #3 on: July 23, 2010, 12:05:01 pm »
As much as I personally do not like it, I too would recommend Ubuntu or Mint.
Offline Mad Penguin
    • Linux in the UK
Re: new to *linux
« Reply #4 on: July 23, 2010, 04:49:47 pm »
Mmm, my feelings exactly ...  :)
I think in summary, the "better" stuff takes a lot more effort and technical expertise ... Ubuntu is certainly the easiest to use and provides the best support, certainly at a 'normal' desktop level ...
Offline jmyeom
Re: new to *linux
« Reply #5 on: July 23, 2010, 10:47:48 pm »
i installed 10.04, i had a look around, got used to the keys and that, where everyhing is, started to customize it,
i think i typed something into terminal, and totally f***ed it, im not going  to try fixing, ill just reinstalled 9.XX, you all say so, so i am as well while it needs fixing,
the mic worked, the webcam worked, everything did, except my wireless dongle, its a 3 wireless dongle,
if anyone can help me with the wireless dongle, my m8 has one, ubunt with a 3 dongle, he just plugged in, diddent work, a few days later it started to work,
so, any help with that would be great :)
JMYEOM
« Last Edit: July 23, 2010, 11:02:35 pm by Mark Greaves (PCNetSpec) »
Re: new to *linux
« Reply #6 on: July 23, 2010, 11:01:23 pm »
I've found that some models of 3g dongles can be a bit awkward, and need to be unplugged and replugged a few times before they switch between CD and 3g Modem modes... sometimes right-clicking on the desktop icon and selecting "Eject" helps.
If you have problems with it after installing 9.10, post back and we'll try to help.
Meanwhile you might want to take a look at this:
http://old.linux.co.uk//docs/center/how-to/recommended-3g-netbook-solution
Starting at Step 11
« Last Edit: July 23, 2010, 11:28:35 pm by Mark Greaves (PCNetSpec) »
Re: new to *linux
« Reply #7 on: July 23, 2010, 11:16:06 pm »
Quote from: Mad Penguin
Ooooh!... You just knew as a Mint user I'd have to disagree with that. ;)
« Last Edit: July 23, 2010, 11:49:27 pm by Mark Greaves (PCNetSpec) »
Offline Mad Penguin
    • Linux in the UK
Re: new to *linux
« Reply #8 on: July 24, 2010, 01:40:18 am »
And you knew I'd just have to come back with "but MINT is just Ubuntu in a green wrapper!"  ;)
Offline jmyeom
Re: new to *linux
« Reply #9 on: July 24, 2010, 01:54:15 am »
got version 9.XX (forgot the version, the link you gave me)
the proplems is still here, i know nothing of linux, so sending me to places with loads of info is not helping,
also, i have no internet connection, so telling me to dl something and run it is proving hard, i need a rundown on what to do,
thanks for you help, and sorry to be a pain
JMYEOM
Offline Mad Penguin
    • Linux in the UK
Re: new to *linux
« Reply #10 on: July 24, 2010, 04:26:55 am »
Mmm, I'm afraid you're going to find it very slow going without an Internet connection ... (!)
Re: new to *linux
« Reply #11 on: July 24, 2010, 04:27:45 am »
I'm not even sure exactly what your problem IS ?... Ubuntu Installation, LAMP Installation, wireless or 3g dongle?
If we're talking about a 3g dongle (and it's on the 3 network)...
1.) Insert your modem into your Netbook .. it should pop up a "New 3G Broadband" window .. select the options you need and click next until the configuration is complete. Note that if you have a PIN set on your SIM card (which you REALLY should!) it will ask you for this when you come to connect... Continue from step 2
If nothing pops up, right click the "network Manager" icon in the system tray by your clock, and select "Edit Connections", click the "Mobile Broadband" tab, click "Add", select your device from the drop-down menu, click "Forward", select "Britain (UK)", click "Forward", select "3", click "Forward", select "Internet" as your Plan and "3internet" as your APN, click "Forward", click "Apply"... now in the window that opened... Continue from step 4.
2.) Now, before you try to connect (!) you will need to change a few settings .. if you right click on the network manager icon in your tooltray (top right) and select Edit connections, the network connections box should appear.
3.) Now click on the Mobile Broadband tab, highlight "3" (or whatever you decided to call your connection when it was auto-added) and click on Edit. Note in the example below I called the connection "Three" rather than "3".
4.) You should now see the screen shown below .. make sure you enter your PIN if there is one set up on your SIM card.
Next you will need to click on the "PPP Settings", this stage in particular is CRITICAL as to an extent, everything else we've done so far is common sense, whereas this is a show stopper unless you know it needs to be changed.
5.) You should now see the second screen as shown in the screenshots at the bottom of this post. First you need to limit the authentication methods to PAP, this is done by clicking on the 'Configure Methods' button and unticking the other unwanted methods.
6.) Next you need to turn off compression, in particular leaving boxes here ticked it likely to prevent the system from establishing a PPP connection with Three's servers, so although you will see a nice clean blue 3G light on your modem, it won't actually produce a working connection.
7.) Click on Apply and we should be ready to attempt a connection.
8.) Right click on the Network Manager icon in the tooltray and "3" should be listed under the connection name you chose. Select this option.
9.) Connecting will probably take around about a minute assuming it's working properly.
Troubleshooting
a) I've waited a minute but I still see a green flashing light and have no connection
    - Check you're actually within range of 3's 3G service
    - Check your PIN setting / make sure it's clear if you have no PIN
b) I've waited a minute and have a blue 3G light, but no connection
    - You've connected to 3, but PPP failed, so check you've turned of your compression settings.
c) I have a connection, but want to disconnection and clicking disconnect on the tooltray item doesn't work
    - yup, bug. Just pull the USB modem from it's socket, works every time.  ;)
d) It worked once, but now when I try to reconnect it sits there
    - it can get confused, try removing the modem, then reboot the netbook
« Last Edit: July 24, 2010, 04:53:52 am by Mark Greaves (PCNetSpec) »
Offline jmyeom
Re: new to *linux
« Reply #12 on: July 24, 2010, 04:57:26 am »
i have tried that
done all that, and does nothing, just says disconnected when i try to connect
Re: new to *linux
« Reply #13 on: July 24, 2010, 05:02:04 am »
Has a 3internet Icon appeared on your desktop?... if so, try right-clicking it and selecting "Eject"... then try to connect.
If that doesn't work, unplug the dongle, wait 10 secs and replug it, open a terminal and enter:
lsusb
hit enter, and post back the results
Offline jmyeom
Re: new to *linux
« Reply #14 on: July 24, 2010, 06:52:49 am »
files & folders > volumes
right click eject... nothing,  no connection
lsusb
bus 1 device 1 :linux 2.0 root hub
bus 2-5 device 1 :linuz 1.1 root hub
bus 1 device 2 :webcam
bus 1 device 6 :Huawei Technologies co., Ltd. E620 USB Modem
