Author Topic: deleted file  (Read 3785 times)
Offline floss
deleted file
« on: August 06, 2010, 06:13:48 pm »
I have accidentally deleted a folder!!! I cant find the recycle bin, Can anyone help me recover it??
Offline Mad Penguin
Re: deleted file
« Reply #1 on: August 06, 2010, 06:28:17 pm »
Ok, under Gnome the trash can is under;
.local/share/Trash/files
Assuming it's not in here, if you were using a network drive/USB key, you can look for a .trash hidden file, but it it's really been deleted, it's gone!
(the 'undelete' functionality you see is provided by the GUI/desktop, it's not a feature of underlying Linux or the Linux filesystem)
Re: deleted file
Offline floss
Re: deleted file
« Reply #2 on: August 06, 2010, 06:40:33 pm »
Thanks for your reply
I cant find a .trash hidden file........am i searching right? On my home screen I have a search box in the right hand corner, is this where I should be searching from?
If yes when I do the search it gives me a drop down of options of where to search ie file system, desktop, user. Which should I use?
When I did a search for .local/share/Trash/files it came up with a warning saying, The search results may be invalid.  There were errors while performing this search. and & show more details.
What am I doing wrong?
Offline Mad Penguin
Re: deleted file
« Reply #3 on: August 06, 2010, 07:01:28 pm »
Easy answer;
Start a terminal session
Type;
cd .local/share/Trash/files
ls
Offline floss
Re: deleted file
« Reply #4 on: August 06, 2010, 07:06:19 pm »
Im sorry but your taking to Mrs thick!!
How do I start a terminal session?
What is a terminal session?
Re: deleted file
Offline floss
Re: deleted file
« Reply #5 on: August 06, 2010, 07:07:24 pm »
SORRY TALKING TO MRS THINK  :P
Offline floss
Re: deleted file
« Reply #6 on: August 06, 2010, 07:09:13 pm »
I am working on a Acer Aspire one, does that make any difference?? dont laugh pls
Offline Mad Penguin
Re: deleted file
« Reply #7 on: August 06, 2010, 07:35:05 pm »
Menus:: Applications -> Accessories -> Terminal
Re: deleted file
« Reply #8 on: August 06, 2010, 10:06:18 pm »
To access the Trash in Linpus Lite
1) On the 4-Panel Home Screen, open My Files or My Documents under Files.
2a) Press Ctrl+T to display the file tree in the side pane and click Trash
Or
2b) In the address bar where it starts My Disk:/// replace it with trash:///
3) The trash folder should now be displayed.
« Last Edit: August 07, 2010, 01:42:43 am by Mark Greaves (PCNetSpec) »
Re: deleted file
