Website
Home
Forum
Help
Search
Calendar
Media
Blog
Login
Register
Tech Zone
Linux Solutions
LiveZilla - brief howto
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: LiveZilla - brief howto (Read 16251 times)
Mad Penguin
Administrator
Hero Member
Gender:
on:
March 17, 2010, 12:03:14 pm »
Just installed "LiveZilla" as a test on the Forum just as a proof of "does it work" for someone - here's the result.
It appears to work very well, i.e. using the Windows Client with a Linux server.
Steps;
Download the LiveZilla .exe from
https://www.livezilla.net/downloads/en/
Install on your Windows PC
Create a server profile for your site
Run the server administrator
Extract the Server setup to a local folder (rather than upload via FTP)
Copy the resulting folder to your Linux web server, in this instance
http://forum.linux.co.uk/LiveZilla
(remembering to set the permissions to match your web server)
Run the remainder of the Server setup, you'll need MySQL setup on your Linux server for this (it's a little confusing, the MySQL details you type into the Windows client are actually copied to the Linux server and executed there)
Now you should be able to log into the Windows client - and the Server side should launch the demo chat application
End-to-End, 15m.
Bit of a shame it's a Windows only client, it does look pretty useful.
Logged
https://twitter.com/garethbult
https://gareth.bult.co.uk
Mad Penguin
Administrator
Hero Member
Gender:
Re: LiveZilla - brief howto
Reply #1 on:
March 17, 2010, 05:27:20 pm »
My mistake .. so here's a shot of the Windows client running on my Linux desktop, together with two active chat sessions ...
http://forum.linux.co.uk/images/livezilla.jpg
Logged
Reply #1 on:
Mark Greaves (PCNetSpec)
Hero Member
Gender:
"-rw-rw-rw-" .. The Number Of The Beast
Reply #2 on:
March 17, 2010, 08:18:49 pm »
Turns out it wasn't too hard to get the LiveZilla Client (for windows) running In WINE as long as you have the correct version (wine1.2 - 1.1.31) I couldn't get it to run in 1.0.1 at all.
I ended up having to uninstall wine 1.0.1 then delete the .wine and .winetrickscache (hidden) directories then install 1.1.31 ...
Updating to 1.1.31 without deleting these directories didn't work.
Prior to step 1
, I had copied all the fonts from a windows (c:\windows\fonts) installation to my
~/.fonts
directory and
rebuilt the font information cache files
Code:
[Select]
sudo fc-cache -vf
Not sure this is necessary, but I figured it can't hurt and now I have my Windows fonts available in Linux which is nice.
1) Install
WINE1.2 version 1.1.31
(may run in later versions) I also installed
wine1.2-dev
, but not sure this was needed.
2) Use
winetricks
to install: '
gdiplus
ie6
dotnet20
mdac25
mdac28
wininet
3) Install the '
LiveZilla_3.1.8.5_Client.exe
4)
NOW
use
winetricks
to install: '
corefonts
if you install corefonts earlier LiveZilla 'may' complain about missing fonts
.... it didn't for me but this may have been because I already had the
ttf-tahoma-replacement
ttf-symbol-replacement
packages installed from the repos
It's not super quick at loading and I haven't
fully
tested it, but it appears to work.
Last Edit: March 17, 2010, 10:19:43 pm by Mark Greaves (PCNetSpec)
Logged
WARNING
: You are logged into reality as 'root'
Mad Penguin
Administrator
Hero Member
Gender:
Reply #3 on:
March 17, 2010, 10:32:29 pm »
Mmm, that didn't work for me ... it kept complaining that either the "Microsoft Sans Serif" font or the "Tahoma" font was missing .. even tho' they were both clearly there ...
Be warned; ttf-tahoma-replacement , will screw with fonts on your web browser for any site (AJAX applications in particular) that tries to set it's own font .. it's very Zimbra unfriendly for example. (it seems not to have a 'bold' mode, apart from not looking good ...)
Last Edit: March 17, 2010, 10:34:33 pm by Mad Penguin
Logged
Hero Member
Gender:
Reply #4 on:
March 17, 2010, 10:39:34 pm »
I had exactly the same problem UNTIL I started again by deleting the .wine and .winetrickscache directories... but this is EXACTLY how I did it
actually...there was 1 other step, but i'm convinced it was 'wrong' so I undid it afterwards and it still worked...
maybe it helped with the installation though.
when I rebuilt the font cache, I also created a symbolic link to ~/.fonts from /root/.fonts
Code:
[Select]
sudo ln -s ~/.fonts /root/.fonts
I'll try uninstalling the ttf-tahoma-replacement package and see if it still works.
Last Edit: July 06, 2010, 12:30:00 am by Mark Greaves (PCNetSpec)
Logged
WARNING
Reply #4 on:
Hero Member
Gender:
Reply #5 on:
March 17, 2010, 10:49:40 pm »
Yup... Still works with the
packages uninstalled in synaptic.
Glad you pointed that out, because I had Zimbra lock up twice since installing them, and it's saved me time tracking the problem down.
Logged
WARNING
goldendragonuk
Jr. Member
Gender:
WTF is Windows!!!
Reply #6 on:
March 18, 2010, 12:32:56 am »
Guys i really appreciate this im really impressed and thankyou for taking the time
Logged
Hero Member
Gender:
Reply #7 on:
March 18, 2010, 05:24:14 pm »
UPDATE:
At the moment running the LiveZilla client in WINE seems very unstable... it starts perfectly, but whilst 'typing' a message it just seems to quit/unload for no apparent reason.
I need to test it on another system, because 'exactly' the same thing happens with 'pidgin' on THIS system, so it could be a problem specific to this box.
I'll update once I've checked.
Last Edit: July 06, 2010, 12:28:24 am by Mark Greaves (PCNetSpec)
Logged
WARNING
Mad Penguin
Administrator
Hero Member
Gender:
Reply #8 on:
March 19, 2010, 12:48:15 am »
Running on KVM using Seamless and RDP seems to be rock solid and works 100% ..
Logged
Reply #8 on:
goldendragonuk
Jr. Member
Gender:
WTF is Windows!!!
Reply #9 on:
March 19, 2010, 01:06:56 am »
ill have to try it out im now installing ubuntu onto this box so can have a play then
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Zone
Linux Solutions
