Author Topic: new installation  (Read 1620 times)
Offline 147718gb
new installation
« on: October 05, 2010, 01:54:30 pm »
Hello
I would like to give my young grandson my old computer and to make it easy I thought Linux would suit
I would like to use a 4GB memory stick to download to.
I do not know much about Linux
Can to help me to proceed
Forgive me if I have not followed the correct way of raising a query
Thank you
147718gb
Re: new installation
« Reply #1 on: October 05, 2010, 02:25:21 pm »
Can I suggest Ubuntu... either 10.04, or wait 5 days for 10.10 to be released... or you can get the 10.10 "RC" (release candidate) now... which will be updated to 10.10 "Final" automatically on the 10th, as long as you have an internet connection.
You can download the ISO image from here:
http://www.ubuntu.com/
and follow the instructions from step 2 here:
http://www.pendrivelinux.com/put-ubuntu-10-04-on-flash-drive-using-windows/
to create a bootable LiveUSB stick, from which you can either run Linux directly, or install it to the PC's hard drive
BTW, I know those instructions are for 10.04, but they should work for 10.10 too.
If you need to create the LiveUSB stick from a Linux PC, let us know which distro you're using.
Hint - If you're using a 4gb USB stick... when asked by the Universal USB Installer, create a 2gb persistence file.
If/when you decide to install to the hard drive, just click the "Install Ubuntu" icon on the LiveUSB desktop or during booting, and follow the instructions here:
10.04 Lucid Lynx installation instructions
http://linux.co.uk/index.php/pages/installation/
10.10 Maverick Meerkat installation instructions
http://www.hackourlives.com/ubuntu-10-10-maverik-meerkat-install-guide/
If you decide on a Linux distribution other than Ubuntu, serach Pendrivelinux.com for instructions on how to create a LiveUSB for your chosed distro.
Great choice by the way... getting him used to Linux young... you might find this article interesting:
http://scienceblogs.com/gregladen/2010/09/linux_in_schools.php
or you may not... who knows ;)
« Last Edit: October 05, 2010, 03:14:03 pm by Mark Greaves (PCNetSpec) »
Offline 147718gb
« Reply #2 on: October 05, 2010, 04:11:06 pm »
Thank you very much   Mark Greaves your quick response and helpful reply
I will give it a try
Thank you
147718gb
