Author Topic: is linux more windows friendly or more mac friendly?  (Read 5072 times)
Offline shtromm
Offline Mad Penguin
Re: is linux more windows friendly or more mac friendly?
« Reply #16 on: June 18, 2010, 09:56:06 pm »
Ok, here we go;
Mac does NOT use the FreeBSD kerne
I'm not sure that's entirely accurate ... if we've any Mac XNU kernel guru's knocking around, correct me if I'm wrong, but as I understand it the concept of a microkernel is much like that of a virtualization hypervisor. Essentially the microkernel does all the basic system resource allocation, but the actual useful stuff all happens inside a virtual environment provided by the microkernel. In much the same way as with a hypervisor, if the 'actual' OS crashes inside it's VM, the microkernel lives on and indeed has the option of restarted the failed OS without restarting 'everything'. (very useful in the context of a hypervisor running a number of VM's / operating systems)
Obviously Mac's don't run lots of Operating Systems, just the one, but again, as I understand it the microkernel starts up a number of "VM's" (for lack of better terminology) and allocates them to different tasks, so for example device drivers run in a virtual environment and if a device driver crashes (something that would be likely to crash a Linux box) the microkernel can simply reload/restart it.
But I think what I'm coming to, is that on a Mac, one of these microkernel VM's actually runs a modified version of BSD, which is what does all the 'real' work (i.e. what you see) .. so .. whereas it's fair to say that a Mac does not run on FreeBSD (because it runs the XNU microkernel) , I also think it's fair to say that it does use the FreeBSD kernel, albeit a modified version.
Effectively I think you could say that Mac OS/X is a microkernel'd version of FreeBSD, maybe we could say FreeBSD NG (?!)
Offline BkS
  • BkS Media Founder
« Reply #17 on: July 07, 2010, 05:05:19 pm »
Ok, here we go;
how do you know all this stuff  ??? :-\?
Offline Mad Penguin
« Reply #18 on: July 07, 2010, 06:23:45 pm »
... I've "lived" it for 30 years ..  :o
Offline BkS
  • BkS Media Founder
« Reply #19 on: July 08, 2010, 02:17:35 pm »
:o.
