Author Topic: Fix Samsung n230 n150 nc10 n148 and others not resuming from suspend in 10.10  (Read 2789 times)
It appears to be a regression in the Maverick (and Natty alpha) kernel... it was fine in Lucid.
Try adding:
intel_idle.max_cstate=0
as a kernel boot parameter.
BE AWARE - When using intel_idle.max_cstate=0 keep an eye on whether your netbook is getting hot during suspend... if it is... try a cstate with a higher value such as intel_idle.max_cstate=3 .. See below for explanation.
Further info:
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/640100?comments=all
Comments #115 onwards.
Instructions...
1.) Edit the /etc/default/grub file... in a terminal enter:
sudo gedit /etc/default/grub
2.) Find the line:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
and change it to:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash intel_idle.max_cstate=0"
3.) Save and exit gedit.
4.) Now update GRUB... back in the terminal enter:
sudo update-grub
5.) Reboot.
Also read comment #129 (onwards) on the above link.
for other working cstate options.
Some people say the following cstates work:
intel_idle.max_cstate=1
intel_idle.max_cstate=2
For an explanation of CSTATE's, and why higher is usually better for battery life... see here:
http://www.hardwaresecrets.com/article/611
It would be VERY helpful for future readers if people would post which cstates work for which Samsung models... TIA :)
« Last Edit: March 21, 2011, 04:08:47 pm by Mark Greaves (PCNetSpec) »
