Author Topic: Aiptek tablet driver for linux is confusing  (Read 9433 times)
Offline Ava
« on: March 13, 2011, 12:28:11 am »
I've downloaded the Linux version from here -
http://www.aiptek.eu/index.php?option=com_product&task=view&productid=184&Itemid=542
I found a Readme file, because there is no clear place to start in the midst of all these strange folders... the instructions are thus (with edited-out gaps):
(click to show/hide)
This makes no sense to me. Where do I start? :( The beginning doesn't make sense...
I should add - I installed the Windows driver using Wine, though it doesn't seem to have worked. The tablet DOES work, but not well enough to really use.
I'd be really grateful for any help :/ Thanks. :)
« Last Edit: March 13, 2011, 02:28:45 am by Mark Greaves (PCNetSpec) »
Re: Aiptek tablet driver for linux is confusing
« Reply #1 on: March 13, 2011, 01:01:31 am »
I wouldn't bother with those drivers, they're quite old and only appear to contain drivers for kernels up to 2.6.30.1
According to this:
https://help.ubuntu.com/community/AiptekTablet
The drivers for your tablet are contained in the xserver-xorg-input-aiptek package, available from the Ubuntu repositories through your package manager (Synaptic).
or can be installed with:
sudo apt-get install xserver-xorg-input-aiptek
BUT - They are in the "universe" repo, so you will have to enable that first.
Whilst enabling "universe", you might as well enable "multiverse" and "partner" at the same time...
Instructions on how to enable the "universe", "multiverse" and "partner" repositories -
Go to System>Administration>Synaptic Package Manager
When Synaptic opens, go to Settings>Repositories>Ubuntu Software (tab)
Put ticks in:
Community maintained Open Source software (universe)
Software restricted by copyright or legal issues (multiverse)
Click the "Other Software" (tab), and put ticks in:
Canonical Partners
and (if you want)
Canonical Partners (Source Code)
Click Close
Now click the "Reload" button on the toolbar.
If you REALLY want to attempt the "Ubuntu" instructions from the ReadMe, let me know.
But be aware they only contain drivers for kernels <= 2.6.30.1 YOUR kernel is 2.6.35 (in Maverick), so they *probably* wont build properly, if at all.
But effectively, what they want you to do is....
Does that make sense ?
I agree, it's not the best laid out ReadMe I've ever seem ;)
« Last Edit: March 13, 2011, 05:34:41 pm by Mark Greaves (PCNetSpec) »
Offline Ava
« Reply #2 on: March 13, 2011, 10:06:22 pm »
Hmm... well, that (the first part, not the readme instructions) did work, thanks :) Though it doesn't seem to have improved the tablet's performance  :-\ Do you think it might just not be very linux-compatible, or have I missed something...?
(The problem is that as I hover the pen over the tablet, it follows it on the monitor - however, after I tap it, it no longer hovers again until I lift the pen up further than that hovering point, and put it back down again... if that makes any sense  :-\)
« Last Edit: March 13, 2011, 10:13:57 pm by Ava »
« Reply #3 on: March 13, 2011, 10:59:32 pm »
See next posting BEFORE doing this.
[END EDIT]
Have you followed the other instructions on the link in my last post?
!) Create a file called 69-xserver-xorg-input-aiptek.rules containing the text:
ACTION!="add|change", GOTO="xorg_aiptek_end"
KERNEL!="event[0-9]*", GOTO="xorg_aiptek_end"
ATTRS{idVendor}=="08ca", ENV{x11_driver}="aiptek", SYMLINK+="input/aiptektablet"
LABEL="xorg_aiptek_end"
Copy that file to the /lib/udev/rules.d directory.
2) Create a file called 10-aiptek.conf containing the text:
Section "InputClass"
        Identifier "pen"
        MatchProduct "Aiptek|AIPTEK|aiptek"
        MatchDevicePath "/dev/input/event*"
        Driver "aiptek"
        Option "SendCoreEvents" "true"
        Option "USB" "on"
        Option "Type" "stylus"
        Option "Mode" "absolute"
        Option "zMin" "0"
        Option "zMax" "511"
EndSection
If you are using Ubuntu 10.10 (Maverick), Copy that file to the /usr/share/X11/xorg.conf.d directory.
3) Run:
xinput get-button-map Aiptek
it will probably return "1 2 3 4 5" then  try remapping the buttons with:
xinput set-button-map Aiptek 1 3 2 4 5
xinput set-button-map Aiptek 2 1 3 4 5
You'll have to work out the button mapping order yourself.
BE AWARE, the button mapping changes won't survive a reboot, so you'll have to script that and add the script to the startup applications.
If you don't know how... once you get it right by manually playing with the mappings, write the command that worked best down and let me know what it is, and I'll talk you through running it automatically at system startup.
« Last Edit: March 14, 2011, 01:57:02 am by Mark Greaves (PCNetSpec) »
« Reply #4 on: March 13, 2011, 11:14:13 pm »
Don't follow the instructions in the previous posting yet.
There seems to be a newer driver for the AIPTEK Slim Tablet U600 Premium II... see here:
https://help.ubuntu.com/community/TabletSetupWizardpen
Instructions to follow.
« Reply #5 on: March 13, 2011, 11:32:43 pm »
OK, installing the newer driver...
First lets get rid of the previous driver, just in case it conflicts...
sudo apt-get purge xserver-xorg-input-aiptek
Now lets add the PPA for the correct drivers:
sudo add-apt-repository ppa:doctormo/xorg-wizardpen
Update the apt cache:
Install the (correct) xserver-xorg-input-wizardpen driver:
sudo apt-get install xserver-xorg-input-wizardpen
Reboot your machine. It should just work.
If it doesn't, let me know as there are also troubleshooting and calibration sections at this link.
« Last Edit: March 13, 2011, 11:46:41 pm by Mark Greaves (PCNetSpec) »
« Reply #6 on: March 14, 2011, 01:27:23 am »
OK folks... installing the xserver-xorg-input-aiptek drivers then following the configuration instructions here:
Caused Ubuntu 10.10 to hang at bootup, so don't bother with them... at least in Maverick.
« Reply #7 on: March 14, 2011, 01:58:33 am »
@Ava
At least you found out how to use a LiveCD to undo changes :)
OK, first thing I want you to do is uninstall the xserver-xorg-input-wizardpen drivers.
sudo apt-get purge xserver-xorg-input-wizardpen
hit enter, and your password when asked... and hit Y when asked if you want to continue.
Next, let's disable the PPA.
when synaptic opens, go to Settings>Repositories>Other Software (tab)
Look for the entry:
http://ppa.launchpad.net/doctormo/xorg-wizardpen/ubuntu maverick main
and remove the tick from box at the beginning of that line.
and if it exists, also remove the tick from:
http://ppa.launchpad.net/doctormo/xorg-wizardpen/ubuntu maverick main (Source Code)
when you've removed the ticks, click Close and if a message about "Repositories changed" pops up, Close that too.
Now, on the main Synaptic toolbar, click the Reload button... when that's done, close Synaptic.
Ok that's got rid of those.
Now let's reinstall the drivers we were first trying to configure... xserver-xorg-input-aiptek... and carry on trying to configure those.
To reinstall them:
Now carry on with the instructions in this posting (above)
http://linuxforums.org.uk/general-help-advice/aiptek-tablet-driver-for-linux-is-confusing/msg39252/#msg39252
« Last Edit: March 14, 2011, 02:00:38 am by Mark Greaves (PCNetSpec) »
Offline Ava
« Reply #8 on: March 14, 2011, 06:06:57 pm »
Well, I got this far:
I get this message:
Error while copying "69-xserver-xorg-input-aiptek.rules".
There was an error copying the file into /lib/udev/rules.d.
Error opening file '/lib/udev/rules.d/69-xserver-xorg-input-aiptek.rules': Permission denied
Offline Ava
« Reply #9 on: March 14, 2011, 06:09:28 pm »
In trying to edit the permissions of /lib/udev/rules.d/69-xserver-xorg-input-aiptek.rules it says -
You are not the owner, so you cannot change these permissions
Apparantly the owner is 'root'... I thought that was me?
Edit - just figured out how to access it, so this shouldn't be a problem now
Edit 2 - err... the udev folder is now empty. :/ At least through root...
Edit 3 - Ok, never mind this, sorted it out now
« Last Edit: March 14, 2011, 06:44:14 pm by Ava »
Offline Ava
« Reply #10 on: March 14, 2011, 06:49:31 pm »
Run:
This comes up:
unable to find device Aiptek
« Reply #11 on: March 15, 2011, 09:24:20 pm »
   Identifier "wizardpen"
   MatchDevicePath "/dev/input/event3"
   MatchProduct "WALTOP|Tablet"
   Driver "wizardpen"
EndSection
Just that... no more.
« Reply #12 on: March 16, 2011, 01:36:01 am »
OK, yet another set of instructions... (if unsure about any of this, look for me in chat)
We're got 2 options here
1) retry the aiptek drivers but with 10-aiptek.conf renamed to 50-aiptek.conf
Remove wizardpen drivers:
then install aiptek drivers:
Now download these 2 files from my dropbox -
http://dl.dropbox.com/u/11876059/50-aiptek.conf
http://dl.dropbox.com/u/11876059/69-xserver-xorg-input-aiptek.rules
now open nautilus as root:
sudo nautilus
navigate to /usr/share/X11/xorg.conf.d and if 10-aiptek.conf exists, delete it.
now copy the 50-aiptek.conf you just downloaded to that same directory (ie. /usr/share/X11/xorg.conf.d)
now navigate to /lib/udev/rules.d
now copy the 69-xserver-xorg-input-aiptek.rules you just downloaded to that same directory (ie. /lib/udev/rules.d)... overwriting the existing file if there is one.
Ok, now reboot and try your tablet.
If your PC won't boot....
remember the pci=nomsi boot parameter
and the Places>Home Folder>xxxGB FileSystem... sudo nautilus
tricks, then delete:
/usr/share/X11/xorg.conf.d/50-aiptek.conf
the renaming of 10-aiptek.conf to 50-aiptek.conf fix can be found here:
http://www.control-alt-deleted.net/genius-g-pen-560-and-ubuntu-1010
and a lot of other places.
2) According to this:
http://ubuntuforums.org/showthread.php?t=1595648
The "Wacom" drivers now work in Ubuntu 10.10... your tablet is actually a rebadged wacom, so worth a go.
First make sure you have all the latest updates on your system as they only work with the latest kernel:
if asked say yes to continue, and wait for it to finish.
now remove the aiptek driver:
Now open Synaptic and see if the xserver-xorg-input-wacom drivers are already installed (ie. green box)
if not, install them... either through Synaptic or with
sudo apt-get install xserver-xorg-input-wacom
open the  /usr/share/X11/xorg.conf.d/50-wacom.conf file (as root) in gedit:
sudo gedit /usr/share/X11/xorg.conf.d/50-wacom.conf
Find the (top section that reads
   Identifier "Wacom class"
# WALTOP needs a patched kernel driver, that isn't in mainline lk yet,
# so for now just let it fall through and be picked up by evdev instead.
#   MatchProduct "Wacom|WALTOP|WACOM"
   MatchProduct "Wacom|WACOM|Hanwang"
   Driver "wacom"
EndSection
and change it to read:
#   MatchProduct "Wacom|WACOM|Hanwang"
   Driver "wacom"
EndSection
Leave the other section as they are.
so the whole file now reads (click the Spoiler button below to view)
Now reboot, and test the tablet.
Worst case scenario... reboot to the LiveCD, and delete the:
file.
« Last Edit: March 16, 2011, 03:58:05 pm by Mark Greaves (PCNetSpec) »
Offline Ava
« Reply #13 on: March 16, 2011, 10:19:41 pm »
Unfortunately the first didn't change it, and with the second I had to delete the file to get the computer working again, so that didn't work either :/
« Reply #14 on: March 20, 2011, 06:02:13 pm »
For future readers, this problem was solved in chat...
These instructions are for 10.10 (Maverick) ONLY... if you are using 10.04 (Lucid) you will have to compile the latest wacom.ko, and update the xorg-macros to version 1.8... see the links at the bottom..
Eventually we settled on the xserver-xorg-input-wacom drivers which are already installed in Ubuntu 10.10 by default.
But we had to edit the:
MatchProduct
line in
Getting the MatchProduct line wrong (on this system) caused the Xserver to stall during bootup, and the system wouldn't boot
The original line read:
but
lsusb -v
reported the Product and Vendor ID's as:
idVendor           0x172f Waltop International Corp.
idProduct          0x0034 Slim Tablet
So editing the line to read:
   MatchProduct "Slim|Waltop|Wacom|WACOM|Hanwang"
Would probably have worked.
But instead we decided to have the hardware matched by vendor instead... so we commented out the MatchProduct line, eg.:
and added this MatchVendor line just beneath it:
   MatchVendor "Waltop|WALTOP|waltop"
so the whole (new), 50-wacom.conf file reads:
#   MatchProduct "Slim|Waltop|WALTOP|WACOM|Wacom"
   Driver "wacom"
EndSection
   Identifier "Wacom serial class"
   MatchProduct "Serial Wacom Tablet"
   Driver "wacom"
EndSection
        Identifier "Wacom serial class identifiers"
        MatchProduct "WACf|FUJ02e5|FUJ02e7"
        Driver "wacom"
EndSection
# N-Trig Duosense Electromagnetic Digitizer
   Identifier "Wacom N-Trig class"
   MatchProduct "HID 1b96:0001|N-Trig Pen"
   Driver "wacom"
   Option "Button2" "3"
EndSection
then (in a terminal) entering:
lsmod
showed the wacom module wasn't listed, so wasn't loading automatically... so we added the line
wacom
to the /etc/modules file.
Rebooted, and Voila... a working tablet.
The important thing was to get the idVendor and/or idProduct lines -
by running:
lsusb -v
then make sure the MatchProduct line and or MatchVendor line in 50-wacom.conf had those as the FIRST ID to look for, as in:
(Worth noting that it DOES seem to be case sensitive... if that first Waltop read WALTOP it stalled the Xserver, because the idVendor string the tablet was using read Waltop not WALTOP... see the lsusb -v output above).
then make sure the wacom module is being loaded.
Useful links:
http://ubuntuforums.org/showpost.php?p=6546012&postcount=1
http://ubuntuforums.org/showpost.php?p=9496609&postcount=1
http://ubuntuforums.org/showpost.php?p=9252390&postcount=1
http://ubuntuforums.org/showpost.php?p=9573142&postcount=1
« Last Edit: April 03, 2011, 11:06:29 pm by Mark Greaves (PCNetSpec) »
