Author Topic: Acer aspire one Linux os not booting up properly  (Read 4712 times)
Offline Alan29
« on: March 28, 2011, 04:06:48 pm »
Hi my son has an acer aspire one netbook that uses the Linux os it has been working fine until last night it would not connect to the Internet . I then noticed there was no lower toolbar that allows you to power down/ shows wifi connection and time . There was also a box in the top left of the screen showing a multi-star icon which displayed a message that this item was not set up yet . How can I get his computer running properly will I need to recover the software if so I do not have a backup
Re: Acer aspire one Linux os not booting up properly
« Reply #1 on: March 28, 2011, 05:01:02 pm »
Can you give us the exact message that is displayed about the "item not having been set up".
First of all, is the panel just set to "auto-hide"... is there a little arrow that when clicked makes the panel reappear, or does moving the mouse cursor to to the very bottom corner of the screen make it reappear ?
If not, you might want to try this...
1.) Open a terminal... you can do this by hitting Alt+F2 and then typing terminal and clicking the Run button
2.) In the terminal enter:
thunar
and hit enter.
3.) When thunar opens hit Ctrl+H to display hidden files. (files/folders that start with "." are hidden by default)
4.) Look for the folder called .config, and enter it. (don't miss the ".")
5.) Look for the folder called xfce4, and enter it.
6.) Look for the folder called panel, right-click it... select "Rename", and change its name to old-panel
7.) now restart the X server by hitting Ctrl+Alt+Backspace (or reboot)
This *should* put the lower panel back to default settings.
If it doesn't work, rename the freshly created panel folder to something like panel-2 and rename old-panel back to panel, and let us know.
For clarity, you are trying to rename the /home/<username>/.config/xfce4/panel directory.
« Last Edit: March 28, 2011, 05:32:55 pm by Mark Greaves (PCNetSpec) »
Offline Alan29
« Reply #2 on: March 29, 2011, 07:04:31 pm »
the icon when hovered over says  New item    This item has not yet been configured
the lower tool bar is not on  autohide and i have tried opening a terminal but when i type in code: it says  bash: code: command not found. i had a problem a while ago where i could not get into terminal because it needed to be accessed by administrator to change anything
Offline Alan29
« Reply #3 on: March 29, 2011, 07:21:46 pm »
hi thanks for your help i managed to sort out the terminal and his computer is working fine again , thankyou for your help
« Reply #4 on: March 29, 2011, 07:22:10 pm »
OK I haven't got an AA1, so you'll have to find the thunar file manager (bit like windows explorer).
It may be....
On the 4-part home screen, open My Files or My Documents under Files.
Hopefully this will open in thunar, then make sure you are in your "Home" directory, and continue from step 3.
I must have been typing this as you were entering your last posting :)
Glad you got it sorted.
« Last Edit: March 30, 2011, 08:51:17 pm by Mark Greaves (PCNetSpec) »
Offline clavery
« Reply #5 on: April 15, 2011, 08:34:17 pm »
also had this problem on my daughters netbook for the last 6 months was ready to chuck it!!!!!! thanks to you and your advice its going again, again many thanks!!!
« Reply #6 on: April 15, 2011, 08:40:44 pm »
You're very welcome... It's nice to know it helped you... thanks for the feedback :)
Offline hartj01
« Reply #7 on: November 27, 2012, 09:03:09 pm »
thunar
and hit enter.
Mark - Incredible.....works perfectly now.....once aagin you enable me to keep my Acer Aspire one ticking over.....your advice is amazing....cheers
Jamie
« Reply #8 on: November 27, 2012, 09:16:18 pm »
Hi hartj01, and welcome to the forum :)
Thanks for the feedback .. it's always nice to hear these things helped someone.
