Author Topic: I'm dualbooting, and I need help on a little matter...  (Read 2930 times)
Offline BkS
  • BkS Media Founder
    • BkS Media
« on: April 08, 2011, 04:15:32 am »
I'm currently dual booting Ubuntu 10.10 with Windows Vista (please don't ask why...). I'm currently using the GRUB2 bootloader, but I need to reset my Vista back to factory settings as I wanna clear it up, and get rid of the clutter that's on it atm. Now I've backed up all my important stuff that I need (docs, music, pictures, files, etc) into Ubuntu, and also onto my USB stick just incase. Now my problem here is this: If and when I goto reset Windows, how will I go about it (because i'm not using the windows bootloader anymore) and will the GRUB MBR files be overwritten?
-BkS.
Re: I'm dualbooting, and I need help on a little matter...
« Reply #1 on: April 08, 2011, 04:27:33 am »
That depends on if your Windows vista disk or partition is an installation disk/partition or an "image", if it's an image, it will completely overwrite the Linux partitions too... putting your system back yo how it came when you bought it.
Where are the installation files... on a CD/DVD, or on a recovery partition ?
If on a CD/DVD did you have to "Create" this disk yourself ?
If not, what is written on the disk ?
Either way GRUB WILL be overwritten, but isn't difficult to reinstall after you have Windows running.
How you go about it depends on your Vista install media, so can you tell us about it.
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #2 on: April 08, 2011, 04:54:27 am »
Well from what I know, Vista is on a recovery partition.
I know that "dev/sda1" is my recovery partition", "dev/sda2" is the partition containing Vista, and "dev/sda3" the partition with Ubuntu on it.
« Reply #3 on: April 08, 2011, 06:13:31 am »
Is there an option to boot the recovery partition in the GRUB menu?
What IS listed in the GRUB menu?
What is the make and model of the PC ?
Be aware - Reinstalling Windows from a "recovery" partition is highly likely to overwrite the rest of the drive completely, and put your system back to factory defualts... so you would probably have to resize the partitions again, and reinstall Ubuntu from scratch.
« Last Edit: April 08, 2011, 06:27:44 am by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #4 on: April 08, 2011, 06:35:39 am »
There is an option to boot the recovery parition in the GRUB menu.
This is what is listed at the boot screen:
Ubuntu 10.10
Ubuntu 10.10 (recovey mode)
Windows Vista (dev/sda1) [this is the recovery partition]
Windows Vista (dev/sda2) [this is the partition which Vista is on]
Windows XP Embedded [I have no clue as too why that's there]
Laptop is an:
Acer Aspire 6920. [need anymore info?]
« Reply #5 on: April 08, 2011, 02:16:15 pm »
OK, Alt+F10 at bootup *should* start the Acer eRecovery Manager... but it WILL erase all traces of Linux, and your data.
Read this thread:
http://forum.notebookreview.com/acer/100076-acer-erecovery.html
BEFORE you do that... be sure to create a restore DVD with the Erecovery software provided... this will make a backup of the Recovery partition, in case something goes wrong... you *should* have been told to do this when you first started the PC from new.
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #6 on: April 09, 2011, 05:32:06 am »
Read this thread:
Thanks Mark, don't wanna seem kind of vain, but I already knew about this  :-\
Is there any way I can back-up, Ubuntu before erasing it completely? I really don't want too, be installing Ubuntu again, as I've lost my LiveCD, and I've no net atm.
Currently using my phone as a modem (DUN), in order to access the net just now, so downloading a new copy is straight out the window.
« Reply #7 on: April 09, 2011, 07:04:38 am »
Technically you could just archive everything in your Linux partition, but you would then need to recreate your swap partition, and reinstall the GRUB bootloader... which would really require a LiveCD... so NO, not easily.  :-\
Maybe it would be *possible*, with something like a parted magic, or clonezilla LiveCD, but you'd still need to download that  ::)
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #8 on: April 10, 2011, 01:38:39 am »
So really what your trying to say is that, I'm up the swanny river without a paddle  ::)?
 I hate not having net :( !
