Author Topic: RedHat finding HBA driver information  (Read 6136 times)
Offline 6910p
« on: April 18, 2011, 09:52:36 am »
morning all
Installed red hat 5.3 last week as part of a work project. the servers have two qlogic hba cards install. i've run lspci and they are listed.
what command could i run to view what driver is installed for the cards? Should mention that i'm a complete novice to linux.
thanks
Cj
Offline 6910p
Re: RedHat finding HBA driver information
« Reply #1 on: April 18, 2011, 10:01:00 am »
should have mentioned these are PCI cards.
looked in /proc had hopped there would be a pci directory
« Reply #2 on: April 18, 2011, 12:31:30 pm »
lshw
(run as root) should list all hardware attached to the system, including the drivers being used and other info.
lsmod
Will list all kernel modules currently being used
« Last Edit: April 18, 2011, 01:37:51 pm by Mark Greaves (PCNetSpec) »
Offline 6910p
« Reply #3 on: April 18, 2011, 02:45:36 pm »
Thanks
