Author Topic: Changing FAT32 permissions on a USB drive?  (Read 17067 times)
Offline BkS
  • BkS Media Founder
    • BkS Media
Re: Changing FAT32 permissions on a USB drive?
« Reply #30 on: June 06, 2011, 01:36:28 am »
Ahh! sweet. Well let's hope it boots up correctly >.<
« Reply #31 on: June 06, 2011, 01:41:08 am »
let me know and we'll try formatting it again... then see if it works AFTER a reboot.
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #32 on: June 06, 2011, 01:53:22 am »
Right. I've tried having a bash at setting the USB ports too 1.1, unplugged & then replugged the USB drive. I did
sudo fdisk -l
it never picked it up. So I rebooted, had to do the REIUSB trick, and then did the sudo command again. Still hasn't picked it up :(
« Reply #33 on: June 06, 2011, 01:55:40 am »
OK, I'm beginning to think the USB stick is buggered, leave it with me and I'll see if I can find any other solutions
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #34 on: June 06, 2011, 02:05:24 am »
Me too >.< shame as well because it's 8GB that I got for free, when I was at college back in Jan  ::) been hardly used.. think 10/11 times perhaps?
I really need to get it working cause I need it now if I'm honest  :P
