Updates:
Similar topics mod installed, currently shown at the end of a topic
Fix Memory sticks [thanks anyway]
Started by theporter2000, June 03, 2011, 12:45:39 AM
Previous topic - Next topic
theporter2000
is there a utility to fix memory sticks
I have Ubuntu 12.04. LTS,  Nautilus 3.4.2, Google Chrome 21.0.1180.57 and Firefox 13.0.1,
TTFN
theporter2000
Mark Greaves (PCNetSpec)
#1
Yes, it's called Super Glue  ;) .. You'll have to give us more than that... What's wrong with it ?
theporter2000
Taken out and not unmounted properly, I've gut them with windows and linux ?
TTFN
theporter2000
Is the USB stick recognised when you plug it into Linux or Windows ?
Are there any error messages in either OS ?
theporter2000
No there never are on either operating system
TTFN
theporter2000
Plug it in, and in Linux, post the output from these 3 commands
dmesg | tail
lsusb
sudo fdisk -l
theporter2000
This is the output
[email protected]:~$ dmesg | tail
[   13.340608] e1000e 0000:00:19.0: irq 45 for MSI/MSI-X
[   13.340888] ADDRCONF(NETDEV_UP): eth0: link is not ready
[   14.286989] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro,commit=0
[   14.756857] e1000e: eth0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: RX/TX
[   14.756862] e1000e 0000:00:19.0: eth0: 10/100 speed: disabling TSO
[   14.757084] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   16.230235] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro,commit=0
[   25.040004] eth0: no IPv6 routers present
[  181.156027] hub 7-0:1.0: over-current change on port 1
[  181.260027] hub 7-0:1.0: over-current change on port 2
[email protected]:~$ lsusb
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 002: ID 192f:0716 Avago Technologies, Pte.
[email protected]:~$ sudo fdisk -l
[sudo] password for gordon:
Disk /dev/sda: 80.0 GB, 80026361856 bytes
255 heads, 63 sectors/track, 9729 cylinders
Disk identifier: 0x0001865f
/dev/sda1   *           1        9347    75078656   83  Linux
/dev/sda2            9348        9730     3069953    5  Extended
/dev/sda5            9348        9730     3069952   82  Linux swap / Solaris
TTFN
theporter2000
Well if you had the USB stick plugged in when you ran those... the stick is DEAD, as it's not being detected AT ALL.
