Author Topic: Getting sound and video[fixed thank you]  (Read 4926 times)
Re: Getting sound and video
« Reply #15 on: June 10, 2011, 07:53:50 pm »
Yes for HDA devices... one is analogue, and one is digital.
I take it that it's still not working ?
have you tried adjusting sound levels in alsamixer ?
Offline theporter2000
  • Full Member
« Reply #16 on: June 10, 2011, 08:11:24 pm »
I have partial sound you tube, web tutorials and I can play a mp4 saved on my computer are OK but If I play a DVD I know some times get sound some times the picture frezae or jumps finishing with the "errors pa_stream_cork() Failed" and "pa_stream_writable_size failed:" both finish with connection terminated
« Last Edit: June 10, 2011, 11:04:24 pm by theporter2000 »
I have Ubuntu 12.04. LTS,  Nautilus 3.4.2, Google Chrome 21.0.1180.57 and Firefox 13.0.1,
TTFN
theporter2000
« Reply #17 on: June 10, 2011, 11:11:11 pm »
That's handy info...
OK, this seems to be related to a known bug in either gstreamer, or pulseaudio... see here:
https://bugs.launchpad.net/ubuntu/+source/pulseaudio/+bug/644644/+index?comments=all
First, make SURE Synatic, Ubuntu Software Centre, and Update manager are ALL CLOSED.
Lets try adding the PPA mentioned and then updating those packages....
First let's install the ppa-purge package, so we can back out of the changes easily if necessary:
If the above command fails with ANY errors, STOP NOW, and let me know... DO NOT carry on with the following instructions yet.
OK, now let's add the PPA:
sudo add-apt-repository ppa:diwic/fighting-rewinds
then update the package cache and upgrade the system
Now reboot, and check your audio.
  • Full Member
« Reply #18 on: June 11, 2011, 12:27:18 am »
Thank you that does appear to have fixed the audio I've got all 3 playing with audio and vision Thank you again for all your help
TTFN
theporter2000
