Author Topic: Batch Resize in The GIMP  (Read 6470 times)
« on: April 10, 2010, 11:26:38 pm »
If you use the GIMP, and want to resize a LOT of pictures in one go... install gimp-plugin-registry then follow these instructions:
Start Gimp. Access the Batch file plugin via the Filters > Batch > Batch Process menu
If you want to resize and output to a different directory, make sure you change the settings on ALL 4 of the following tabs, BEFORE selecting 'Start' (by default it will output to the same directory and convert to BMP)
Input tab - Select files to add to the batch
Resize tab - Select the size you want (and enable)
Output tab - Select file type (BMP, JPG etc.)
Rename tab - Select dir (directory for output)
It can do a lot more than just resize... Turn, Blur, Colour, Resize, Crop, Sharpen and Rename... or any combination of these.
More info here:
http://ulyssesonline.com/2008/09/22/batch-resize-images-with-gimp/
Offline zebedee
  • I've just joined! Still learning
Re: Batch Resize in The GIMP
« Reply #1 on: November 10, 2010, 09:44:23 pm »
I realise this is old, but So am I.
Just want to say thank you for this,  I have been using Mihov which only runs on win*
« Reply #2 on: November 10, 2010, 10:22:42 pm »
Offline Smiler
  • Full Member
« Reply #3 on: July 28, 2011, 02:03:40 pm »
Ooh, that's handy to know. Up until now I was using two seperate programs, Gimp and Pixresizer (or whatever it's called). Then again, I've also been using XP for far too long!  :P
Nothing to see here.
