Author Topic: How to set up a Dial-Up connection [Ubuntu and Mint]  (Read 7614 times)
« on: April 11, 2010, 01:19:08 am »
To set up a Dial-Up connection:
If you have a working internet connection, install gnome-ppp from the synaptic package manager.
once installed go to:
Menu -> Internet -> GNOME PPP
open a terminal and type:
gnome-ppp
And enter your dial-up details.
If you don't have the correct permissions to use gnome-ppp... open a terminal and enter:
sudo adduser YOURUSERNAME dip
sudo adduser YOURUSERNAME dialout
[make sure you replace YOURUSERNAME with your Linux login name]
If you NEED to set up dial-up, and you don't have a working internet connection so can't install gnome-ppp, follow these instructions:
1) Open a terminal and type:
sudo pppconfig
Select 'Create a connection'... fill in all the information and save... (remember what you put in the provider field, you will need this info later)
2) In a terminal type:
sudo touch /etc/resolv.conf
sudo touch /etc/ppp/options
3) Reboot.
4) In a  terminal type
pon YOURPROVIDERNAME
Replace YOURPROVIDERNAME with the provider name you entered in pppconfig... This should start the modem dialing.
5) Whilst connected to the net, open a terminal and type:
sudo apt-get install gnome-ppp
6) To end the internet session, In a terminal type:
poff
:) from now on use - Menu -> Internet -> GNOME PPP to connect :)
« Last Edit: April 11, 2010, 01:50:52 am by Mark Greaves (PCNetSpec) »
