Author Topic: Patching kernel 2.6.38 to allow FFB for Logitech wheels.  (Read 7511 times)
Offline BkS
  • BkS Media Founder
« on: September 05, 2011, 01:55:45 pm »
So I have my wheel working using the LTWheelConf tool, however I have no force feedback and in order to do this I need to patch the kernel. There's just one thing. I haven't a scooby what to do, so I'll post what I know/find. Perhaps someone round here can help me solve the last piece of the puzzle.
So from what I know, I need to patch the kernel to allow FFB,however the only bits of information I have right now is this wiki page and some advice a member from another forum gave me. Problem is, the kernel they talk about is very old, as is Ubuntu 8.10 and so I'd imagine quite a few things have changed.
From what I know it's about adding the device id.
in drivers/hid/hid-core.c add:
{ HID_USB_DEVICE(USB_VENDOR_ID_LOGITECH, USB_DEVICE_ID_LOGITECH_DFGT_WHEEL) },
in drivers/hid/hid-ids.h add:
#define USB_DEVICE_ID_LOGITECH_DFGT_WHEEL // DFGT_ID_HERE
in /drivers/hid/hid-lg.c add:
{ HID_USB_DEVICE(USB_VENDOR_ID_LOGITECH, USB_DEVICE_ID_LOGITECH_DFGT_WHEEL), .driver_data = LG_FF },
I just haven't a clue what I'm supposed to be doing and I'd rather someone helped me out, because I don't want to be patching my kernel for it to then screw up and them me going through the whole process of fixing it.
Re: Patching kernel 2.6.38 to allow FFB for Logitech wheels.
« Reply #1 on: September 05, 2011, 02:19:25 pm »
Can you post the model of your wheel, and (with the wheel attached) the output from:
lsusb
so we can get the manufacturer:device ID's
If I'm reading this correctly:
http://lwn.net/Articles/438003/
and a few other places... isn't force feedback support added/enabled by default for G25/G27 devices in kernels >= 2.6.39 ?
In which case wouldn't it be easier to install 2.6.39, or wait for Oneric (11.10) ?
If you provide the device ID's I can check in the 2.6.39 kernel source, because I'm currently running that ;)
Or (Mwuhahahaha) post me your wheel and I'll test it for you "for a year or two", oops sorry I meant "and post it right back" :)
« Last Edit: September 05, 2011, 04:03:55 pm by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
« Reply #2 on: September 06, 2011, 02:46:23 am »
lsusb
Model of wheel: Logitech Driving Force GT.
Manufacturer id: Bus 005 Device 005: ID 046d:c29a Logitech, Inc.
We can install 2.6.39 if you want, but Oneric is due next month which I was going to upgrade to anyway. I will never send my wheel XD It stays with me :P
« Reply #3 on: September 06, 2011, 02:03:25 pm »
Heh... It's not if *I* want... it's YOUR call :)
« Last Edit: September 06, 2011, 02:15:15 pm by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
« Reply #4 on: September 06, 2011, 09:34:04 pm »
Ok, well "I" want too then. ::)
« Reply #5 on: September 06, 2011, 10:02:21 pm »
OK, you're going to want 3 files...
For 32bit Ubuntu 11.04 desktop edition:
linux-image-2.6.39-020639rc4-generic_2.6.39-020639rc4.201104191410_i386.deb
linux-headers-2.6.39-020639rc4_2.6.39-020639rc4.201104191410_all.deb
linux-headers-2.6.39-020639rc4-generic_2.6.39-020639rc4.201104191410_i386.deb
For 64bit Ubuntu 11.04 desktop edition:
linux-image-2.6.39-020639rc4-generic_2.6.39-020639rc4.201104191410_amd64.deb
linux-headers-2.6.39-020639rc4-generic_2.6.39-020639rc4.201104191410_amd64.deb
Now put them all in a directory and call it something like kernel-2.6.39
Move that direcory into your home directory
and run these 2 commands:
cd ~/kernel-2.6.39
sudo dpkg -i linux-*.deb
Wait for it to leave you back at an $ prompt (may take a short while)... then reboot.
Once your back at the desktop, run:
uname -r
Output should be -
Her's where the files are actually located:
http://kernel.ubuntu.com/~kernel-ppa/mainline/v2.6.39-rc4-natty/
And remember, you can always select the older kernel fron the GRUB boot screen if necessary.
« Last Edit: September 06, 2011, 11:08:37 pm by Mark Greaves (PCNetSpec) »
« Reply #6 on: September 06, 2011, 10:30:41 pm »
Or would you prefer to try kernel 3.1.0-rc4 ? .. it's listed as for Oneric, but seems to work fine on my system ;)
Though it *did* mention the possibility of some ATI firmware being missing during the install... but everything seems OK (so far).
Offline BkS
  • BkS Media Founder
« Reply #7 on: September 07, 2011, 02:56:37 am »
Two things.
Number one, I can't remember which bit-version I installed, what's the terminal command to check that?
Number two, before we proceed, a guy from the LFS forum has built a kernel patch for 2.6.38. See here for details.
So do we still update, or? I say "we" as in, you're helping me decide because you're far more knowledgeable then me. :Pz
« Reply #8 on: September 07, 2011, 09:47:03 am »
First check to see if you are running 64bit... because if you are, you may be better off using his patched kernel
uname -a
here's the output for 64bit Ubuntu
Linux mark 3.1.0-0301rc4-generic #201108290905 SMP Mon Aug 29 09:11:07 UTC 2011 x86_64 x86_64 x86_64 GNU/Linux
Offline BkS
  • BkS Media Founder
« Reply #9 on: September 07, 2011, 09:22:49 pm »
I got:
Quote from: Terminal
Linux bally-laptop 2.6.38-11-generic #48-Ubuntu SMP Fri Jul 29 19:05:14 UTC 2011 i686 i686 i386 GNU/Linux
« Reply #10 on: September 07, 2011, 09:30:13 pm »
Hmmm he's uploaded a 64bit kernel, you've got 32bit Ubuntu .. which will be a problem, as you have 32bit libs and software installed :(
« Last Edit: September 07, 2011, 09:32:02 pm by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
« Reply #11 on: September 08, 2011, 06:20:27 am »
Well I have an Intel Core 2 Duo processor, I *believe* it is 64-bit compatible. I guess I'll update to 64-bit version of Natty? or a beta version of Oneric? or Mint 11? I could back-up files etc to the win7 box for now.
« Last Edit: September 08, 2011, 06:27:34 am by BkS »
« Reply #12 on: September 08, 2011, 03:11:53 pm »
Sounds like a plan ;)
Offline BkS
  • BkS Media Founder
« Reply #13 on: September 08, 2011, 03:21:46 pm »
So which to upgrade too? Oneric beta, or Natty? Mint is out the window, didn't like the look of it at all and I don't like KDE either :P
« Reply #14 on: September 08, 2011, 03:57:28 pm »
Ultimately the choice is yours, but I'd probably go for Natty, till Oneiric has been out for a while :)
« Last Edit: October 19, 2011, 02:16:10 pm by Mark Greaves (PCNetSpec) »
