Author Topic: audio recorder for Linpus  (Read 3872 times)
Offline mako6
  • Full Member
« on: September 06, 2011, 06:19:30 pm »
Know any high-quality audio recprder for Linpus Lite? Want wave- or at least 2 megs/min MP3
Re: audio recorder for Linpus
« Reply #1 on: September 06, 2011, 07:37:38 pm »
Try Audacity... it's in your software repositories, so to install, open a terminal enter:
sudo yum -y install audacity
Audacity homepage:
http://audacity.sourceforge.net/
Source:
http://timwright.hubpages.com/hub/First-Steps-To-Acer-Aspire-One-Perfection
« Last Edit: September 06, 2011, 07:49:31 pm by Mark Greaves (PCNetSpec) »
Offline mako6
  • Full Member
« Reply #2 on: December 17, 2011, 09:52:26 pm »
Couldn't seem to find some files- but was downloading something that I should ahve stopped. Tried it again, and it tried to install (without having requisite files, I think) and then just hung. Sorry forgot to copy
the terminal output.. How does one install this directly- if it's right- newest fedora version:       http://koji.fedoraproject.org/koji/buildinfo?buildID=278793
I seem to remember, I tried this simple fix a long while ago and it didn't work then either
« Reply #3 on: December 18, 2011, 01:16:03 am »
Firstly,your link points to the latest build of Audacity for Fedora 16 .. if Linpus is unable to install the dependencies for its own version of Audacity, you stand NO chance with this version.
Secondly, try this:
sudo yum -y install fedora-release
wget http://download1.rpmfusion.org/free/fedora/updates/8/i386/rpmfusion-free-release-8-6.noarch.rpm
sudo rpm -U rpmfusion-free-release-8-6.noarch.rpm
And lastly .. I know I keep saying this, but you could install Audacity or any other software with a few mouse clicks in PeppermintOS .. lets count them.
Menu (click) System Tools>Software Manager (click) Searchbox (click) enter "audacity", select Audacity item (click), select "install" button (click) .. installed and working (and a recent version of Audacity too).
« Last Edit: December 18, 2011, 03:07:06 am by Mark Greaves (PCNetSpec) »
Offline mako6
  • Full Member
« Reply #4 on: December 19, 2011, 04:37:26 pm »
Maybe I have bigger problem- it did fall off desk 1/2M and clatter on floor 2 days ago. Here is output:
No it didn't copy.
On first fedora install, downloaded 3-4 files- then got a "segmentation error" on attempted install. Then when tried it again, it tried to install, and then hung again without finishing for 5 minures  till I closed terminal.
Have a feeling might have damaged or corrupted files- is there a way to erase what I did and start anew? Without risking removing vital system files, that is?  I don't understand a blanket instruction, like install fedora- release. Isn't that going to do a massive update, or only some newest files? if something does actually take several minutes, do warn us, after a minute or so w no apparent activity, I'm convinced whatever you're doing has failed.
« Reply #5 on: December 19, 2011, 06:58:28 pm »
Nope, that first command is only to add the fedora repository to your sources list ..
Why ? .. what's happening with your AA1 now ?
Offline mako6
  • Full Member
« Reply #6 on: December 21, 2011, 02:28:12 pm »
Well, it's just hanging (doing nothing for 5 minutes) on that first fedora install instruction. Everything else works fine. That just updates the newest files, right?
« Reply #7 on: December 21, 2011, 03:39:59 pm »
No it was supposed to update the key to the fedora repository .. maybe it no longer works because they've archived that repository, as fedora 8 is no longer supported .. if that's the case, I reckon you'll have major difficulty adding anything that requires dependencies.
