Author Topic: Installing Google Earth in Ubuntu  (Read 3753 times)
« on: September 09, 2011, 11:26:15 pm »
To install Google Earth from the UbuntuUpdates.org 3rd Party PPA Repository:
http://www.ubuntuupdates.org/ppas/80
Using this method downloads and installs Google Earth directly from dl.google.com .. and as it is a PPA repository, your Ubuntu Updater will make sure you always have the latest version
First make sure all package managers, and he updater are closed.
Then open a terminal and run these 4 commands:
wget -q -O - "https://dl-ssl.google.com/linux/linux_signing_key.pub" | sudo apt-key add -
sudo sh -c 'echo "deb http://dl.google.com/linux/earth/deb/ stable main" >> /etc/apt/sources.list.d/google.list'
sudo apt-get install google-earth-stable
Google Earth should now be installed :) .. Have fun.
« Last Edit: September 16, 2011, 08:24:56 pm by Mark Greaves (PCNetSpec) »
Offline theporter2000
  • Full Member
Re: Installing Google Earth in Ubuntu
« Reply #1 on: September 16, 2011, 08:01:13 pm »
help this is the responce I get : gordon@gordon-desktop:~$ wget -q -O - https://dl-ssl.google.com/linux/linux_signing_key.pub | sudo apt-key add -
[sudo] password for gordon:
gpg: no valid OpenPGP data found.
I have Ubuntu 12.04. LTS,  Nautilus 3.4.2, Google Chrome 21.0.1180.57 and Firefox 13.0.1,
TTFN
theporter2000
« Reply #2 on: September 16, 2011, 08:32:56 pm »
Were you connected to the internet at the time ?
  • Full Member
Re: Installing Google Earth in Ubuntu[fixed thank you]
« Reply #3 on: September 17, 2011, 08:21:07 pm »
I though I was but after the problems of late I try again it worked
TTFN
theporter2000
