Author Topic: Adding Microsoft .NET Framework 3.5 to WINE?  (Read 27177 times)
Offline BkS
  • BkS Media Founder
« on: September 15, 2011, 10:39:50 pm »
Is there a way I can install Microsoft .NET Framework 3.5 in WINE? I need it for a program (which I know runs in WINE) for it to be able to work. It's not urgent, but "the sooner the better" as the saying goes.
-BkS. ::)
Re: Adding Microsoft .NET Framework 3.5 to WINE?
« Reply #1 on: September 15, 2011, 11:08:38 pm »
Use winetricks to install it:
cd ~
wget http://kegel.com/wine/winetricks
bash /home/bally/winetricks dotnet35
Be aware it will install.net 2.0, then .net 3.0 first.
Or if winetricks is already installed... fire it up, then select -
Select the default wine prefix
Click OK
select -
Install a Windows DLL or component
Click OK
Tick dotnet35
Click OK
Apparently it warns that .net 3.5 can't be installed in wine yet.... even .net 3.0 fails on my machine :(
WineHQ also lists .net 3.5 support as "garbage"
« Last Edit: September 15, 2011, 11:34:39 pm by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
« Reply #2 on: September 15, 2011, 11:48:38 pm »
That sucks badly :( I really wanting to use this program.
