Author Topic: Gotta love Apple...  (Read 3123 times)
Offline BkS
  • BkS Media Founder
    • BkS Media
Gotta love Apple...
« on: September 25, 2011, 09:25:19 pm »
I'm currently running a Apple Aluminum Keyboard (with number pad) and a Apple Mighty Mouse, my problem being is that, the "function" buttons F1 - F19 & "Eject" don't work sometimes. It's crazy if I'm honest because it's only with certain applications like Firefox, Photoshop (ran via WINE), LFS (ran via WINE), Empathy  and Nautilus (at times.) There are a couple of others as well, anyway I've been in the keyboard layouts, I've tried all options for Apple and none seem to be working, I also get a KBR kernel issue too at times!
output from lsusb:
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 003: ID 046d:c29a Logitech, Inc.
Bus 004 Device 002: ID 138a:0001 DigitalPersona, Inc Fingeprint Reader
Bus 002 Device 009: ID 046d:09a4 Logitech, Inc. QuickCam E 3500
Bus 002 Device 008: ID 05ac:0304 Apple, Inc. Optical USB Mouse [Mitsumi]
Bus 002 Device 007: ID 05ac:0221 Apple, Inc. Aluminum Keyboard (ISO)
Bus 002 Device 005: ID 064e:a103 Suyin Corp.
Bus 002 Device 002: ID 05ac:1006 Apple, Inc. Hub in Aluminum Keyboard
output from lsmod:
bally@bally-laptop:~$ lsmod
Module                  Size  Used by
ipt_MASQUERADE         12759  1
xt_state               12578  1
ipt_REJECT             12541  2
xt_tcpudp              12603  4
iptable_filter         12810  1
nf_nat_h323            17002  0
nf_conntrack_h323      58101  1 nf_nat_h323
nf_nat_pptp            12629  0
nf_conntrack_pptp      13839  1 nf_nat_pptp
nf_conntrack_proto_gre    13606  1 nf_conntrack_pptp
nf_nat_proto_gre       12767  1 nf_nat_pptp
nf_nat_tftp            12489  0
nf_conntrack_tftp      12953  1 nf_nat_tftp
nf_nat_sip             17087  0
nf_conntrack_sip       29412  1 nf_nat_sip
nf_nat_irc             12643  0
nf_conntrack_irc       13349  1 nf_nat_irc
nf_nat_ftp             12649  0
nf_conntrack_ftp       13359  1 nf_nat_ftp
iptable_nat            13182  1
nf_nat                 25416  9 ipt_MASQUERADE,nf_nat_h323,nf_nat_pptp,nf_nat_proto_gre,nf_nat_tftp,nf_nat_sip,nf_nat_irc,nf_nat_ftp,iptable_nat
nf_conntrack_ipv4      19589  4 iptable_nat,nf_nat
nf_conntrack           81469  18 ipt_MASQUERADE,xt_state,nf_nat_h323,nf_conntrack_h323,nf_nat_pptp,nf_conntrack_pptp,nf_conntrack_proto_gre,nf_nat_tftp,nf_conntrack_tftp,nf_nat_sip,nf_conntrack_sip,nf_nat_irc,nf_conntrack_irc,nf_nat_ftp,nf_conntrack_ftp,iptable_nat,nf_nat,nf_conntrack_ipv4
nf_defrag_ipv4         12729  1 nf_conntrack_ipv4
ip_tables              26957  2 iptable_filter,iptable_nat
x_tables               29538  7 ipt_MASQUERADE,xt_state,ipt_REJECT,xt_tcpudp,iptable_filter,iptable_nat,ip_tables
cryptd                 20352  0
aes_x86_64             17208  1
aes_generic            38279  1 aes_x86_64
binfmt_misc            17456  1
parport_pc             36823  0
ppdev                  17069  0
vesafb                 13761  1
arc4                   12529  2
snd_usb_audio         111390  1
snd_usbmidi_lib        24919  1 snd_usb_audio
snd_hda_codec_realtek   331704  1
nvidia              10709116  64
snd_hda_intel          32881  2
iwlagn                331644  0
snd_hda_codec         103315  2 snd_hda_codec_realtek,snd_hda_intel
snd_hwdep              13604  2 snd_usb_audio,snd_hda_codec
snd_pcm                95911  3 snd_usb_audio,snd_hda_intel,snd_hda_codec
iwlcore               167108  1 iwlagn
mac80211              286741  2 iwlagn,iwlcore
snd_seq_midi           13324  0
snd_seq_midi_event     14899  1 snd_seq_midi
uvcvideo               67214  0
snd_seq                61397  2 snd_seq_midi,snd_seq_midi_event
hid_apple              13237  0
snd_rawmidi            30435  2 snd_usbmidi_lib,snd_seq_midi
joydev                 17412  0
videodev               81982  1 uvcvideo
v4l2_compat_ioctl32    16728  1 videodev
snd_timer              29396  2 snd_pcm,snd_seq
snd_seq_device         14462  3 snd_seq_midi,snd_seq,snd_rawmidi
cfg80211              177524  3 iwlagn,iwlcore,mac80211
snd                    67204  17 snd_usb_audio,snd_usbmidi_lib,snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_seq,snd_rawmidi,snd_timer,snd_seq_device
psmouse                72840  0
video                  19176  0
serio_raw              13166  0
soundcore              12680  1 snd
snd_page_alloc         18484  2 snd_hda_intel,snd_pcm
coretemp               13411  0
lp                     17825  0
parport                46339  3 parport_pc,ppdev,lp
hid_logitech           26427  0
ff_memless             12966  1 hid_logitech
usbhid                 46693  1 hid_logitech
hid                    90763  3 hid_apple,hid_logitech,usbhid
ahci                   25854  4
atl1e                  37225  0
libahci                26563  1 ahci
P.S. I know Apple products are "bad" but the Aluminum & Mighty mouse were "must have's."  :3
Re: Gotta love Apple...
« Reply #1 on: September 25, 2011, 09:40:09 pm »
Open a terminal and run:
xev
now you can test the F keys actually work, and get the key make/break codes.
After that, you've got some reading to do on how to apply your own key mappings:
http://gunnarwrobel.de/wiki/Linux-and-the-keyboard.html
Enjoy ;)
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #2 on: September 25, 2011, 11:26:22 pm »
I'll be honest. That amount of writing put me of reading it. Isn't there another way? :(
« Reply #3 on: September 25, 2011, 11:33:23 pm »
If Ubuntu doesn't contain a working keymap for your keyboard... I'm guessing the only way would be to create your own.
But if I come across anything on my travels, I'll let you know.
« Reply #4 on: October 04, 2011, 09:44:44 pm »
See if this describes your problem:
https://help.ubuntu.com/community/AppleKeyboard
And if:
echo 2 | sudo tee /sys/module/hid_apple/parameters/fnmode
Temporarily fixes the function keys
Temporarily = Won't survive a reboot.
« Last Edit: October 04, 2011, 09:47:39 pm by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #5 on: October 04, 2011, 09:53:27 pm »
I feel like a right noob now. I didn't know I had to press and hold "fn" to make the function keys work. :(
Thanks for this Mark!
EDIT: I still have one problem though... the "eject" button doesn't seem to work. I remember having it work with some Apple configuration just can't remember which... so is there anyway I could get this to work, or will I have to do the keymap thing which I honestly don't understand very much? XD
« Last Edit: October 04, 2011, 09:55:20 pm by BkS »
« Reply #6 on: October 04, 2011, 10:13:37 pm »
Yes... in the Application lens, start Keyboard Shortcuts
Click Add
Command: eject
Click Apply
Look in the left hand (Action) column for the CDeject item (under Custom Shortcuts).
in the right hand (Shortcut) column, click where it says Disabled .. it should change to New shortcut...
Now hit your eject key on the keyboard, and the eject command will now be bound to that key (or key combo).
« Last Edit: October 04, 2011, 10:16:54 pm by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #7 on: October 04, 2011, 10:23:13 pm »
Spot on! Cheers Mark! ;)
