Author Topic: Finally got around to networking the house  (Read 45187 times)
Offline pooky2483
Re: Finally got around to networking the house
« Reply #195 on: August 07, 2012, 07:02:29 pm »
Ahh .. YES then .. the mounts and bootloader are all sorted now.
Many thanks for the help, it looks very complicated, what was done.
Kubuntu 18.04LTS 64bit|KDE 5.47.0|Plasma 5.12.19|QT 5.9.5|Linux 5.4.0.54-generic|M5A78L-M USB3|BIOS 2101|AMD PhenomII X4 965 3400+|P8H77-I Motherboard NIC|32.0GB PC3-10600 1333Mhz CL9 ( 9-9-9-24 ) DDR3
Offline pooky2483
« Reply #196 on: August 28, 2013, 10:06:50 pm »
I've installed the Kubuntu desktop and for some reason I now, when I use the XboX to view the films on my PC  I can't see them.
I have given the XboX (wired) a fixed IP address of 192.168.1.203.
Ushare.conf
(click to show/hide)
This is a list of ushare -x in terminal. Could the reason the XboX is not seeing the files be 'UPnP MediaServer listening' being assigned a different port number than what is in the above config file? Why is it not assigning it the one in the config file?
Offline SeZo
« Reply #197 on: August 28, 2013, 10:21:11 pm »
Does this give you any clue?
[email protected]:/home/pooky2483/Documents# ushare -x
Interface eth0 is down.
Recheck uShare's configuration and try again !
Try:
ip link
That should give you which network adapter you are using.
« Last Edit: August 28, 2013, 10:31:37 pm by SeZo »
Offline pooky2483
« Reply #198 on: August 28, 2013, 10:39:50 pm »
[email protected]:/home/pooky2483/Documents# ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 16436 qdisc noqueue state UNKNOWN
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP qlen 1000
    link/ether 00:24:8c:bc:10:83 brd ff:ff:ff:ff:ff:ff
3: virbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN
    link/ether 46:63:1d:e8:93:ed brd ff:ff:ff:ff:ff:ff
'Interface eth0 is down'
That's a bug in the programming or something as it says that all the time as it has done in the past but still works, ask Mark about it and he'll say it's nothing to worry about.
Offline SeZo
« Reply #199 on: August 28, 2013, 10:52:48 pm »
OK. Can you ping your Xbox from Kubuntu?
Where and how do you set the fixed IP addresses?
You need to set your DHCP pool on your router, then set each PC to a fixed address outside of that pool.
Offline pooky2483
« Reply #200 on: August 28, 2013, 11:11:25 pm »
On the XboX itself
Already done, a couple of days ago. DHCP pool 192.168.1.2-200 so static IP's are 192.168.1.201-255
Offline pooky2483
« Reply #201 on: August 28, 2013, 11:13:56 pm »
Unable to give you a result on the Xbox ping, I'll be able to do it later.
Offline pooky2483
« Reply #202 on: September 09, 2013, 09:07:42 pm »
Sorted it, jumped over to the Netgear forum and got it sorted, I had to set up a port forwarding rule for each XboX.
Offline pooky2483
« Reply #203 on: October 05, 2013, 01:52:17 pm »
Correction on my last post... It's NOT working.
When I type:
sudo kate /etc/ushare.conf
I get
[sudo] password for pooky2483:
QDBusConnection: session D-Bus connection created before QCoreApplication. Application may misbehave.
Error: "/var/tmp/kdecache-pooky2483" is owned by uid 1000 instead of uid 0.
Error: "/tmp/kde-pooky2483" is owned by uid 1000 instead of uid 0.
Error: "/tmp/ksocket-pooky2483" is owned by uid 1000 instead of uid 0.
kdeinit4: Shutting down running client.
Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
kbuildsycoca4 running...
Why is this and how can I correct it.
I am unable to share my content to either of my XboX's.
I have even given them static IP's - Front Room XboX is 192.168.1.203 and the Bedroom is 192.168.1.205
The Kubuntu PC static IP is 192.168.1.201
« Reply #204 on: October 05, 2013, 02:48:24 pm »
Dunno what the problem with Ushare is, but those error messages (from what I'm reading) can be safely ignored.
I take it the file IS opened ?
Offline pooky2483
« Reply #205 on: October 05, 2013, 03:00:15 pm »
Don't quite get what you mean there?
Also, I'm sure I installed Samba (if that's needed?) and how can I check it's working, if that's possible?
Offline pooky2483
« Reply #206 on: October 05, 2013, 03:01:15 pm »
I'm thinking it's a problem with the router but don't know how to fix it!!!
« Reply #207 on: October 05, 2013, 03:57:41 pm »
When you ran the command that gave you all those errors .. I take it the file DID open for editing in kate ?
service smbd status
so which ports did you forward through the router, and where to ?
I'm noty convinced anything needs forwarding .. though if you're running a firewall on the Kubuntu box, you may have to open some ports.
Offline pooky2483
« Reply #208 on: October 05, 2013, 05:06:00 pm »
Yes
service smbd status
[email protected]:~$ service smbd status
smbd start/running, process 956
I've forwarded it through port(s) 49200 - 49210. As sometimes ushare does not start back using port 49200 but increases the port number.
And I do NOT have a firewall running in Kubuntu, ONLY the router firewall.
« Reply #209 on: October 05, 2013, 05:16:44 pm »
OK, what's the contents of your ushare.conf
I'm still not sure you need those firewall rules in your router AT ALL .. the routers firewall stands between the local network and the internet .. not between PC's on the local network.
and you still don't say WHERE the rules forward the ports to ?
My guess is you've forwarded those ports from the internet to your Kubuntu box (or Xboxes) .. so are now blocking ushare.
