Author Topic: Finally got around to networking the house  (Read 45303 times)
Re: Finally got around to networking the house
« Reply #45 on: November 15, 2011, 09:07:05 pm »
In a terminal enter:
nautilus /media/Win-Video
does a window open showing the contents of the Windows Video drive ?
« Last Edit: November 15, 2011, 09:10:55 pm by Mark Greaves (PCNetSpec) »
Offline pooky2483
« Reply #46 on: November 15, 2011, 09:13:10 pm »
Yes, it opens showing files and a notification at the bottom pops up saying read only
Kubuntu 18.04LTS 64bit|KDE 5.47.0|Plasma 5.12.19|QT 5.9.5|Linux 5.4.0.54-generic|M5A78L-M USB3|BIOS 2101|AMD PhenomII X4 965 3400+|P8H77-I Motherboard NIC|32.0GB PC3-10600 1333Mhz CL9 ( 9-9-9-24 ) DDR3
« Reply #47 on: November 15, 2011, 09:19:37 pm »
Hmm .. I wonder if this is a "permissions" issue .. I've never trued sharing files via ushare that were outside my Home directory.
I'll test it later, and get back to you.
Offline pooky2483
« Reply #48 on: November 15, 2011, 09:23:25 pm »
No probs.
In the mean time could you recommend a good read so I can understand the system and the commands a bit better
« Reply #49 on: November 15, 2011, 09:30:52 pm »
See if there's anything here that takes your fancy:
http://linuxforums.org.uk/index.php?topic=232.0
There's also the Getting Started with Ubuntu 10.10.pdf here:
http://dl.dropbox.com/u/11876059/Getting%20Started%20with%20Ubuntu%2010.10.pdf
bit outdated as far as the user interface, but the command line stuff will still translate.
Offline pooky2483
« Reply #50 on: November 15, 2011, 09:55:43 pm »
Thanks for them, got lots of reading to do now.
 8)
Offline galaxytdm
  • Ubuntu 11.04
  • Sr. Member
  • Something Something dark side
« Reply #51 on: November 15, 2011, 11:11:09 pm »
Are you connected via ethernet or wirelessly with the computer you are trying to configure?
If you need help ask a professional, then act upon their advice.
Anything less and you're just wasting peoples time.
Offline pooky2483
« Reply #52 on: November 16, 2011, 10:46:13 am »
Wired to Virgin router, the new type (I'm on 30) then it's wireless to the XboX in the front room and wired to the one in our bedroom.
« Reply #53 on: November 16, 2011, 01:19:39 pm »
Quick question .. does the Xbox list the Ushare server at all "Ubuntu_PC_Shares" ?
Reason I ask is because BkS has had all sorts of difficulties with local networking with one of the latest virgin boxes.
Offline pooky2483
« Reply #54 on: November 16, 2011, 02:13:20 pm »
It doesn't show any, 'No computers found'
« Reply #55 on: November 16, 2011, 04:02:49 pm »
Post the contents of your /etc/ushare.conf file again (as it is now):
gedit /etc/ushare.conf
You *are* just selecting VIDEOS on the Xbox, and NOT that Media centre thingy ?
« Last Edit: November 16, 2011, 04:17:05 pm by Mark Greaves (PCNetSpec) »
Offline pooky2483
« Reply #56 on: November 16, 2011, 04:48:48 pm »
ushare.conf ;
(click to show/hide)
If I'm thinking you mean the 'Media Centre' that didn't work for my XboX as it wasn't the Media Centre version and is not Vista or 7 (they ommitted it from the XP version I used for some reason.
Or you mean XBMC or that other one I mentioned when I first posted m message, no as I have removed XBMC as I think it's crap and the other one, I've not got.
« Reply #57 on: November 16, 2011, 05:45:14 pm »
Try changing the:
USHARE_NAME=Ubuntu PC Shares
line to:
USHARE_NAME=ubuntu
USHARE_NAME=Ubuntu_PC_Shares
sudo gedit /etc/ushare.conf
SAVE the file .. Then reboot the PC and the Xbox
As I'm not sure if spaces are allowed.
What I meant was on the Xbox360, select My Xbox > Video Library .. is the PC listed down the left hand side ?
and NOT, My Xbox > Windows Media Center
Offline pooky2483
« Reply #58 on: November 17, 2011, 02:39:25 am »
Nope, it's not listed.
I'm just going to retry, will post results in a few.....
Neither worked
How do you know what port the XboX is on?
I've just tried it on the other XboX in the bedroom (wired) and it cant find anything either.
I found this http://nexus172.wordpress.com/2009/04/26/how-to-stream-video-to-your-xbox360-using-ubuntu-ushare/
Scroll down to see
Then I start uShare when I need it with:
    ushare -x  (-x is for xbox compatible mode)
It works now, do/can I put that command in the ushare.conf file for it to run every time on a boot up?
« Last Edit: November 17, 2011, 03:25:31 am by pooky2483 »
« Reply #59 on: November 17, 2011, 06:03:45 am »
Well I'm surprised that worked, as this line:
USHARE_ENABLE_ XBOX=yes
is supposed to be putting it in xbox compatibility mode anyway ???
Anywho .. there's nothing stopping you adding that command in "Startup Applications"
