Author Topic: Dell 1501 wireless card  (Read 3556 times)
Offline Omegaman
« on: November 11, 2011, 06:07:46 pm »
How do I get my wireless card to work?
Re: Dell 1501 wireless card
« Reply #1 on: November 11, 2011, 07:14:27 pm »
Can you open a terminal and enter:
sudo lshw -C network
hit enter, and your password when asked .. the post the output from that command back here.
Offline Omegaman
« Reply #2 on: November 11, 2011, 07:44:42 pm »
whats a termial?
Offline BkS
  • BkS Media Founder
« Reply #3 on: November 11, 2011, 07:53:04 pm »
It's a command shell, where your enter command syntax's and you receive outputs from those commands. You'll find it in older version of Ubuntu by going to Applications > Accessories > Terminal and on newer version of Ubuntu 11.04 or greater by typing into the dash "terminal".
Offline Omegaman
« Reply #4 on: November 11, 2011, 08:05:16 pm »
ok, I found it, now how do I copy the output, so that I can paste it here?
Offline BkS
  • BkS Media Founder
« Reply #5 on: November 11, 2011, 09:28:22 pm »
Just drag your mouse from the end of the output to where you entered the command. Then right-click > copy.
« Reply #6 on: November 12, 2011, 07:13:06 pm »
Yup, same way as you'd copy any other text :) .. insert cursor at beginning, hold left mouse button and drag to the end (so the text is highlighted), then right-click on it and select copy
then right-click in here and select paste.
« Last Edit: November 14, 2011, 11:33:59 pm by Mark Greaves (PCNetSpec) »
