Author Topic: kodak printer drivers on acer aspire one impus lite  (Read 17345 times)
Re: kodak printer drivers on acer aspire one impus lite
« Reply #45 on: February 28, 2012, 08:43:39 pm »
Yep, it's a "Cloud" distro .. so most apps are run from the internet, such as gmail, google-docs etc .. but they run in their own window.
There's nothing to stop you installing the full blown apps to the HDD though, such as LibeOffice, Thunderbird, etc. .. as it uses the Ubuntu repos.
Offline john-i-am
  • Full Member
« Reply #46 on: February 28, 2012, 09:06:49 pm »
OK, on your Windows PC, download the PeppermintOS (two) ISO image from here:
http://peppermintos.info/dl2/Peppermint-Two-i386-06052011.iso
or see here:
http://peppermintos.com/download/
Once you've got the ISO image .. download Universal USB Installer from here:
http://www.pendrivelinux.com/downloads/Universal-USB-Installer/Universal-USB-Installer-1.8.6.9.exe
or see here:
http://www.pendrivelinux.com/universal-usb-installer-easy-as-1-2-3/
Start Universal USB Installer, and at ..
Step 1 .. In the drop down list, select PeppermintOS (Two)
Step 2  .. point it at the ISO image you downloaded
Step 3 .. Choose your (already plugged in >= 4GB) USB stick .. probably best to let it format it too, so backup its contents first.
Step 4 .. Set the slider to at least a 2GB persistence file .. so you can save changes, like adding the printer driver, LibreOffice, Firefox, etc. to test.
(the persistence option *says* optional, but you NEED one)
Heres a pic of the Universal USB Creator interface
Click Create .. and wait till it's done .. it will take a while, and *may* appear to have stopped .. but just wait till it says it's "Done" .. as in the following pic
Pic of Universal USB Installer .. Installing to USB Stick
Once the LiveUSB has been created, click Close, plug it into your AA1, then turn ON your AA1 .. as soon as you see the first screen (Acer Empowering People), hit the F12 key to access the boot device selection screen .. and select the USB stick as the drive to boot from and hit Enter to boot.
When asked, select "Try Peppermint" NOT "Install Peppermint"
Be aware .. running from a USB stick will be quite a bit slower that running it from the internal SSD after installation, so don't draw any conclusions about speed at this point ;)
I *can* tell you that once installed, it takes about 15 - 20 seconds longer to boot than Linpus Lite .. but once booted it loads/runs applications just as quickly .. and has access to all the latest software.
Once you've got that going .. let me know ..  and I'll tell you how to install your printer drivers, and some other stuff such as LibreOffice, Firefox (rather than Chrome), Thunderbird (if you need it) .. and how to achieve things like auto login, and get the wireless to auto start every boot, etc.
mark, think i'm gonna need a helping hand with the printer driver, just bought an hp email printer so should work fine. is there a way of creating short cuts on the desktop? it doesnt drag and drop like windows i guess?
cheers, john
« Reply #47 on: February 28, 2012, 09:11:42 pm »
Shortcuts to what ?
If you mean add icons from the menu's .. it's in the Peppermint tutorial isn't it ?
just right-click a menu item and select "Add to Desktop"
« Last Edit: February 28, 2012, 09:17:17 pm by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
« Reply #48 on: February 28, 2012, 09:19:31 pm »
Am I correct in thinking Peppermint 2 is based on Ubuntu 11.10? If so, I believe the option of creating "shortcuts" or more commonly known in the Linux world as "Launchers" was broken. You can still do it by terminal command though.
gnome-desktop-item-edit ~/Desktop/ --create-new
You'll most likely need to install the Gnome Panel dependencies though so:
sudo apt-get install --no-install-recommends gnome-panel
It's probably best if you wait for Mark to come in here. :P
Offline john-i-am
  • Full Member
« Reply #49 on: February 28, 2012, 09:26:40 pm »
Shortcuts to what ?
if it is i guess i missed it, sorry if its been covered already, i'm right clicking chromium from the menu and it just opens a new page.
« Reply #50 on: February 28, 2012, 09:47:53 pm »
RIGHT-click it in the menu .. then select "Add to desktop" :)
Not Left-click .. if you right-click it, you should see a drop menu with 2 options:-
Add to desktop
Properties
OK, just in case you're clicking the wrong place.
Bottom left of your screen on the panel you'll see a Peppermint icon and the word "menu" .. click that, move your cursor up to "Internet", move your cursor across to "Chromium Web Browser", RIGHT-CLICK your mouse/trackpad, click "Add to desktop" .. there should now be a Chromium icon on the desktop.
[EDIT 2]
For your Kodak ESP 5250 (AIO) printer .. down lad ths file:
http://sourceforge.net/projects/cupsdriverkodak/files/latest/download
then doube-click it .. when gdebi opens, click the "Install" button,
Once that's installed, go to menu>System Tools>Printing to set up your printer.
Just for information, the homepage of the c2esp driver is here:
http://cupsdriverkodak.sourceforge.net/
and files (on sourceforge) here:
There is also a SANE backend there that may allow you to use the scanner.
It is also (after installing the above driver) possible to set up the printer through the CUPS interface by going to this address:
http://localhost:631
in your web browser.
then going to Administration>Add Printer
BTW, when your browser prompts for your username and password .. that's your Peppermint username and password.
« Last Edit: February 28, 2012, 10:40:29 pm by Mark Greaves (PCNetSpec) »
Offline john-i-am
  • Full Member
« Reply #51 on: February 29, 2012, 04:52:24 am »
Add to desktop
Properties
[EDIT 2]
yeah was clicking in wrong place, thanks mark, will try out the printer too
Offline john-i-am
  • Full Member
« Reply #52 on: February 29, 2012, 05:07:29 am »
this may sound obvious but how do i change my peppermint installation to uk settings, seems during set up i hit us and not uk, the clock is 5 hours behind too,
thanks, john
Offline john-i-am
  • Full Member
« Reply #53 on: February 29, 2012, 05:15:53 am »
when i click it in the menu its greyed out, with a padlock on click to make changes button
Offline BkS
  • BkS Media Founder
« Reply #54 on: February 29, 2012, 05:28:32 am »
The padlock is there so you don't change any settings by accident, just hit the padlock and change the time to UK settings, usually just enter your location and it'll do the work for you. The hit the padlock again and close the window. Done. :D
« Reply #55 on: February 29, 2012, 11:39:06 am »
I'm going to apologise before I say this but ..
Didn't you take that as a hint .. click the padlock to make changes ;)
Offline john-i-am
  • Full Member
« Reply #56 on: February 29, 2012, 07:47:23 pm »
thanks BKS, yeah i should have figured that one out.
Offline john-i-am
  • Full Member
« Reply #57 on: February 29, 2012, 07:51:02 pm »
mark, its true, i'm not the sharpest when it comes to these sort of things. should have a go at more stuff but scared i will do some damage that will cause me problems
Offline BkS
  • BkS Media Founder
« Reply #58 on: February 29, 2012, 08:30:52 pm »
You won't progress unless you take risks. ::)
Just use a bit of common sense and read up on things before you do anything system-wise and always backup your backup. You can never be too sure. :P
« Reply #59 on: February 29, 2012, 08:40:37 pm »
Hey, screwing up your system, then fixing it, is the best way to learn .. and half the fun ;)
And I wonder why people think I'm a bit of a geek :)
« Last Edit: February 29, 2012, 08:44:09 pm by Mark Greaves (PCNetSpec) »
