Author Topic: Linux equivalent to Peerblock (PC)  (Read 5539 times)
Offline pooky2483
« on: November 25, 2011, 11:18:38 pm »
Ive just downloaded the iplist-0.29.tar.bz2 file and I'm not confident enough on what to do with it to install it. Any help...
Re: Linux equivalent to Peerblock (PC)
« Reply #1 on: November 25, 2011, 11:59:25 pm »
iplist from here:
https://launchpad.net/~ssakar/+archive/ppa/+build/2012495
seems to work on my Ubuntu 11.10 64bit system .. even though it was packaged for 10.10 64bit (Maverick)
Direct download link:
https://launchpad.net/~ssakar/+archive/ppa/+build/2012495/+files/iplist_0.29-0ubuntu1_amd64.deb
then just double-click the downloaded file to install .. then when Ubuntu Software Centre opens, click Install
You can UNINSTALL it with
sudo apt-get remove --purge iplist
if you decide you don't want it.
