Author Topic: downloading peppermint  (Read 10565 times)
Re: downloading peppermint
« Reply #15 on: December 11, 2011, 10:07:44 pm »
Hope it all goes/went well, but any problems .. you know where to come ;)
I'd be VERY surprised if you don't prefer it to Linpus .. but let me know.
I've edited the first part of the PeppermintOS tutorial to reflect your problems with the newer version of Universal USB Installer:
http://linuxforums.org.uk/index.php?topic=9782.msg70071#msg70071
« Last Edit: December 11, 2011, 10:34:01 pm by Mark Greaves (PCNetSpec) »
Offline banko
  • Full Member
« Reply #16 on: December 12, 2011, 06:50:57 pm »
much better than linpus lite,
impressed with the speed very quick
thoroughly recommend to any one thinking of changing, anyone used to windows will find it very easy,
Your tutorial Mark was so easy to follow
 even my son was impressed you came back with a solution to the usb problems so quick,
so again a big thanks
 and next an install of ubunto onto my desktop pc, so be ready for a barrage of questions,
« Reply #17 on: December 12, 2011, 07:46:44 pm »
Glad you like it .. IMHO, PeppermintOS makes Linpus look silly, and is SO much easier to use.
Also glad to hear the tutorial was helpful :)
Heh .. well this is the Linux community ;)
Good luck with Ubuntu on your desktop, and if you have any problems let us know and we'll see if we can help .. that's what we're here for.
Offline banko
  • Full Member
« Reply #18 on: December 13, 2011, 07:48:34 pm »
Mark
did the automatic login from your tutorial, works perfect,
but i still have to
enter password for keyring 'default' to unlock.
an application wants access to the keyring default but it is locked
any ideas how i can do this automatically
thanks
keith
« Reply #19 on: December 13, 2011, 08:17:28 pm »
Open NetworkManager and delete your wireless connection.
then set up your wireless connection again .. if at ANY time (whilst setting up the wireless connection again) it asks for a "keyring" password .. leave it blank .. it will complain about "unsafe storage", but accept it anyway.
Offline banko
  • Full Member
« Reply #20 on: December 15, 2011, 08:59:02 pm »
no luck with this one
on peppermints site it says they "don’t recommend connecting automatically" and if you do, a keyring password request will pop up.
i deleted connection but when i re stalled connection the only key i had to give was the router key,
« Reply #21 on: December 15, 2011, 10:40:06 pm »
It hasn't popped up on mine ???
Do you want to try fix the keyring password AND keep auto login ? (see fix below)
Disable the auto login ? (if you'd rather have to enter your password each login, let me know and I'll tell you how)
To fix the wireless "keyring" password
If you haven't already .. do whatever you have to do to get a working wireless connection that prompts you for the "keyring"password every time you boot .. boot, and enter your keyring password so you are connected.
Then open a terminal and run this command:
mv -v ~/.gnome2/keyrings/default.keyring ~/.gnome2/keyrings/default.keyring.old
Expected output from that command =
'/home/<username>/.gnome2/keyrings/default.keyring' -> '/home/<username>/.gnome2/keyrings/default.keyring.old'
If that command runs without error .. REBOOT.
When your system restarts, you will be prompted by "Authentication required by wireless network" .. enter your WEP or WPA key, and click the "Connect" button.
You will THEN be prompted to "Choose password for new keyring" .. leave BOTH fields BLANK, and click the "OK" button.
You will then be warned about "Store passwords unencrypted?" .. click the "Use Unsafe Storage" button.
You should not be prompted for a keyring password for wireless again. :)
« Last Edit: December 16, 2011, 12:42:21 am by Mark Greaves (PCNetSpec) »
Offline banko
  • Full Member
« Reply #22 on: December 16, 2011, 05:15:41 pm »
Done
