Author Topic: Opening tabs for devices  (Read 1265 times)
Offline pooky2483
« on: December 10, 2011, 06:40:44 pm »
Is there a limit as to how many tabs I can have open re opening them for devices as mine keep 'crashing' after opening 7 in 1 window.
Re: Opening tabs for devices
« Reply #1 on: December 10, 2011, 06:52:27 pm »
tabs for devices ??
tabs in what ?
If you mean in the nautilus file manager .. there *was* an issue with nautilus crashing in 11.10 which I *assumed* was fixed but could be wrong.
The fix was to (if present) delete ~/.nautilus with:
rm -rf ~/.nautilus
and completely uninstall the nautilus-open-terminal plugin with:
sudo apt-get remove --purge nautilus-open-terminal
If you absolutely MUST have the "Open Terminal Here" option .. there is *supposed* to be a workaround using a script rather than the nautilus plugin here:
http://www.cyberciti.biz/faq/linux-gnome-open-terminal-shell-prompt-here/
Don't ask me how well this works though :)
Another known issue that only seemed to apply to the Gnome (Classic) desktop in 11.10 was that nautilus sometimes crashed because of the Ubuntu One client .. so if you don't use Ubuntu One, you can uninstall the client with:
sudo apt-get remove ubuntuone-client-gnome
« Last Edit: December 10, 2011, 07:34:14 pm by Mark Greaves (PCNetSpec) »
Offline pooky2483
« Reply #2 on: December 10, 2011, 09:13:44 pm »
Sorry, I meant these tabs;
I'll uninstall Ubuntu One as I don't use it, ta.
