I'll read your peppermint post, Mark, but a new OS seems too much hassle- there's always some hardware that doesn't work
If so, wouldn't this be a way to update system a bit?
can that cause anything else to not work?
Missed a crucial step on the battery disassembly- test em in situ, as they say in chemistry. Turns out, as is common with batteries=- only one was bad, on the right end, and didn't need to rip them all out. Replacing the one bad one- $6 here might give me another year, since it failed at a little over 1 1/2 yr. Second- the contacts are pressed on the battery, since was going to toss it, heated them a little with one of those acetylene lighters, which didn't have much effect. This is a useful enterprise to have a second or emergency battery, or just use them. If you can fit em, they work fine in 3 AAA cell LED flashlights and will run them forever. 2 together would give 7.4V, fine for emergency mobile recharge of phone batteries. These were Samsung - pretty standard, but if you have a bigger laptop battery, finding a single dead cell could save you serious bucks.
