Author Topic: Installing the MiniDLNA media streaming server in Ubuntu  (Read 61611 times)
Offline galaxytdm
  • Ubuntu 11.04
  • Sr. Member
  • Something Something dark side
Re: Installing the MiniDLNA media streaming server in Ubuntu
« Reply #15 on: December 21, 2011, 11:49:17 pm »
Your original method is working fine for me, so is there any real need to change it?
If you need help ask a professional, then act upon their advice.
Anything less and you're just wasting peoples time.
« Reply #16 on: December 22, 2011, 12:00:37 am »
Not really .. any update to the minidlna package in the repo's *may* break your MiniDLNA installation .. but you're OK to fix it IF/WHEN that happens if you want .. up to you ;)
« Last Edit: December 22, 2011, 12:02:11 am by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
« Reply #17 on: July 30, 2012, 04:09:55 pm »
I'm getting parsing errors when trying to rebuild the database.
[email protected]:~$ minidlna -R
parsing error file /etc/minidlna.conf line 11 : + "A" for audio  (eg. media_dir=A,/home/bally/Downloads)
parsing error file /etc/minidlna.conf line 12 : + "V" for video  (eg. media_dir=V,/home/bally/Downloads)
rm: cannot remove `/var/lib/minidlna/files.db': Permission denied
Here's what my /etc/minidlna.conf looks like:
(click to show/hide)
« Reply #18 on: July 30, 2012, 04:13:05 pm »
How did you install minidlna ?
The ereason I ask is becuase when I instaled it a while ago from the default repos .. it didn't work.
Let me know which distor/version/architecture and I'll take another looksee.
Looks like wherever you got it from, the version you're running stores the files.db file at a different location
instead of
/var/cache/minidlna/files.db
Try this:-
sudo minidlna -R
sudo chown -R bally:bally /var/lib/minidlna
then try:
minidlna -R
and let me know if it now works.
« Last Edit: July 30, 2012, 04:31:34 pm by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
« Reply #19 on: July 30, 2012, 05:07:26 pm »
I install it from the default repos, in Ubuntu 12.04 x64.
Output from commands:
[email protected]:~$ sudo minidlna -R
[email protected]:~$ sudo chown -R bally:bally /var/lib/minidlna
« Last Edit: July 30, 2012, 05:08:58 pm by BkS »
« Reply #20 on: July 30, 2012, 06:14:49 pm »
First kill minidlna:
sudo service minidlna stop
sudo killall minidlna
Then run:
sudo sudo apt-get build-dep minidlna
and let it install any dependencies.
Then run:
sudo gedit /etc/minidlna.conf
And make your minidlna.conf read:-
# port for HTTP (descriptions, SOAP, media transfer) traffic
port=48200
# network interfaces to serve, comma delimited
network_interface=wlan0
# set this to the directory you want scanned.
# * if have multiple directories, you can have multiple media_dir= lines
# * if you want to restrict a media_dir to a specific content type, you
#   can prepend the type, followed by a comma, to the directory:
#   + "A" for audio  (eg. media_dir=A,/home/jmaggard/Music)
#   + "V" for video  (eg. media_dir=V,/home/jmaggard/Videos)
#   + "P" for images (eg. media_dir=P,/home/jmaggard/Pictures)
media_dir=A,/home/bally/Music
media_dir=P,/home/bally/Pictures
media_dir=V,/home/bally/Videos
# set this if you want to customize the name that shows up on your clients
friendly_name=BALLY-LAPTOP
# set this if you would like to specify the directory where you want MiniDLNA to store its database and album art cache
db_dir=/var/cache/minidlna
# set this if you would like to specify the directory where you want MiniDLNA to store its log file
log_dir=/var/log
# this should be a list of file names to check for when searching for album art
# note: names should be delimited with a forward slash ("/")
album_art_names=Cover.jpg/cover.jpg/AlbumArtSmall.jpg/albumartsmall.jpg/AlbumArt.jpg/albumart.jpg/Album.jpg/album.jpg/Folder.jpg/folder.jpg/Thumb.jpg/thumb.jpg
# set this to no to disable inotify monitoring to automatically discover new files
# note: the default is yes
inotify=yes
# set this to yes to enable support for streaming .jpg and .mp3 files to a TiVo supporting HMO
enable_tivo=no
# set this to strictly adhere to DLNA standards.
# * This will allow server-side downscaling of very large JPEG images,
#   which may hurt JPEG serving performance on (at least) Sony DLNA products.
strict_dlna=no
# default presentation url is http address on port 80
presentation_url=http://192.168.0.2:48200/
# notify interval in seconds. default is 895 seconds.
notify_interval=900
# serial and model number the daemon will report to clients
# in its XML description
serial=12345678
model_number=1
# use different container as root of the tree
# possible values:
#   + "." - use standard container (this is the default)
#   + "B" - "Browse Directory"
#   + "M" - "Music"
#   + "V" - "Video"
#   + "P" - "Pictures"
# if you specify "B" and client device is audio-only then "Music/Folders" will be used as root
#root_container=.
then run:
sudo gedit /etc/default/minidlna
and make it read:-
# Defaults for minidlna initscript
# sourced by /etc/init.d/minidlna
# installed at /etc/default/minidlna by the maintainer scripts
# These options can be set to modify the behavior of the minidlna init script.
# The options commented out show the default values.
# Start the daemon if set to "yes"
START_DAEMON="yes"
# Path to the configuration file
CONFIGFILE="/etc/minidlna.conf"
# Path to the log file
#LOGFILE="/var/log/minidlna.log"
# User and group the daemon should run as
USER="bally"
GROUP="bally"
# Additional options that are passed to the daemon
#DAEMON_OPTS=""
then run:
sudo mkdir -v /var/cache/minidlna
minidlna -R
sudo chown -R bally:bally /var/cache/minidlna
Now REBOOT and go test the it on your phone/Xbox/whatever .. there should be a device listed as BALLY-LAPTOP, and you should be able to access any supported media files you put in the:-
~/Music
~/Pictures
~/Videos
directories on the Ubuntu box.
« Last Edit: July 30, 2012, 07:06:16 pm by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
« Reply #21 on: July 31, 2012, 11:47:49 am »
Works like a charm. Cheers old yin! ;D
Using MediaHouse from the Play store, as suggested by Mark. I'm on the free version, and it suits my needs perfectly.
Now all I need to do, is install minidlna on my home-server. Can I use a comma to add extra folders to the minidlna.conf?
« Reply #22 on: July 31, 2012, 01:09:29 pm »
I don't know if it supports comma separated values .. but there's nothing stopping you doing it like this:
media_dir=/path/to/new/share1
media_dir=/path/to/new/share2
media_dir=/path/to/new/share3
media_dir=/path/to/new/share4
etc.
Thanks for the feedback on the MediaHouse UPnP / DLNA Browser software .. as one of my sons has jujst become the proud owner of an HTC Desire C .. so we finally have sommat Android in the house :)
For other readers the MediaHouse UPnP / DLNA Browser can be found at these links
MediaHouse UPnP / DLNA Browser (free edition)
MediaHouse Pro-Edition UPnP / DLNA Browser (commercial edition)
Offline BkS
  • BkS Media Founder
« Reply #23 on: July 31, 2012, 01:46:51 pm »
Tell your son I wish him good luck with his HTC... ::) Not a problem, streams HD 1080p video just fine on my S3, quality is amazing as well.
I'll give that suggestion a try, it might be a cleaner way of keeping track of folders, etc, as well. Now to read over the PPA instructions. I should really update the NAS to 12.04... I'll do it later.
« Reply #24 on: July 31, 2012, 02:00:44 pm »
What were the rolled eyes about ? .. the kids a college student that just went out and got himself a job (his first "proper" job) during the holidays .. he can't afford an S3, and I think he's done himself proud earning the money for his HTC himself .. I'm certainly proud of him :)
« Last Edit: July 31, 2012, 02:05:53 pm by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
« Reply #25 on: July 31, 2012, 02:05:37 pm »
What were the rolled eyes about ? .. the kids a college student that just went out and got himself a job during the holidays .. he can't afford an S3, and I think he's done himself proud earning the money for his HTC himself :)
You've gotten the wrong end of the stick, I wasn't meaning that in a bad way. It's great he's got a job, just HTC's are notorious for hardware faults, and lack of updates from the manufacturer. I thought you of all people would've understood that, assuming you read The Reg, and what not?
All I meant was, expect him to ask you to fix it when it breaks.
« Last Edit: July 31, 2012, 02:07:50 pm by BkS »
« Reply #26 on: July 31, 2012, 02:08:38 pm »
Ahh .. apologies then .. nope, I've had no real need to follow what goes on with smartphones .. and the choice was his anyway :)
Offline BkS
  • BkS Media Founder
« Reply #27 on: July 31, 2012, 02:12:42 pm »
Just be armed with a USB cable. ;D
Anyway, looks like that PPA is outdated. My home-server can't get the fingerprint, and if it does, it closes the TLS connection.
Error: can't find signing_key_fingerprint at https://launchpad.net/api/1.0/~stedy6/+archive/stedy-minidlna
[email protected]:~$ sudo add-apt-repository ppa:stedy6/stedy-minidlna
Error reading https://launchpad.net/api/1.0/~stedy6/+archive/stedy-minidlna: Peer closed the TLS connection
Looks like I'm moving nowhere fast.
« Reply #28 on: July 31, 2012, 02:17:16 pm »
Forget that PPA if the one in 12.04 is now working.
OK, which version you runnin on the server ?
[EDIT 2]
Try manually adding the signing key:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 661F5D0B
« Last Edit: July 31, 2012, 02:32:53 pm by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
« Reply #29 on: August 01, 2012, 09:17:58 pm »
It seems my box not getting the PPA seems to be a problem in itself. It's not adding any ppa I try. It fails, yet all my packages are up-to-date. So either an update has broke it, or it's a sign to update the damn thing. I really don't wanna go through all the hassle of setting everything up again. -___-
