Author Topic: Installation problems  (Read 8351 times)
Offline alexishbob2
« on: December 29, 2011, 05:11:13 pm »
Hey, I am currently a Windows user trying to install Ubuntu on my computer; however, every time I try the screen glitches up displaying random lines of colour on the screen during the installation process and splitting the screen in half once it is installed, rendering it unusable.  The unit I'm using is an Advent DT1411 and I'd just like to know if there are any known compatibility issues with this and if there is anything I can do to fix this, or another distro I could use instead. Thanks in advance.
Re: Installation problems
« Reply #1 on: December 29, 2011, 09:07:08 pm »
Would I be right in saying the Advent Advent DT1411 has a Core i5 2320 (Sandy Bridge) CPU ?
Has it got an ATI Radeon HD6700M (add in) graphics card ? .. as well as a graphics adapter built into the motherboard (onboard) ?
If so, have you tried the onboard card ?
« Last Edit: December 29, 2011, 09:08:39 pm by Mark Greaves (PCNetSpec) »
Offline alexishbob2
« Reply #2 on: December 29, 2011, 09:54:37 pm »
You are correct in everything you just said, but honestly, I have no idea how I would go about doing it. I don't really know too much about computers, but I'm doing my best to learn, so please excuse my ignorance.
« Reply #3 on: December 29, 2011, 10:47:31 pm »
From a quick search the problem seems to be related to the Sandy Bridge CPU containing an integrated graphics adapter (on-chip) that doesn't seem to be correctly switched off when an add-in graphics card is also present.
From what I'm reading there seems to be be a way round the problem, but I want to do some more homework on the issue before suggesting anything .. can you check back tomorrow night(ish), and I'll see what I can come up with :)
« Last Edit: December 29, 2011, 10:51:55 pm by Mark Greaves (PCNetSpec) »
Offline alexishbob2
« Reply #4 on: December 29, 2011, 10:57:38 pm »
Wow, thank you very much, you have been incredibly kind
« Reply #5 on: December 29, 2011, 11:24:06 pm »
Can you answer me a question .. when you boot to an Ubuntu LiveCD, and select "Try Ubuntu", do you end up at a working desktop, or are your graphics still messed up ?
Offline alexishbob2
« Reply #6 on: December 30, 2011, 12:05:40 am »
I have no idea, sorry, I'm doing my best to find out for you now, I'll let you know ASAP
« Reply #7 on: December 30, 2011, 12:25:00 am »
If you need help or have any questions .. just ask :)
Offline alexishbob2
« Reply #8 on: December 30, 2011, 12:36:57 am »
Ok, just got it working there now. It works fine, but the colours are still very glitchy; it is usable however.
« Reply #9 on: December 30, 2011, 12:41:42 am »
OK, great .. can you hit Ctrl+Alt+T (at the same time) .. a terminal should open, in the terminal type:
sudo lshw -C display
and hit the enter key.
give the command a few seconds to finish, and post back what the output was.
be aware Linux commands ARE case sensitive, so that's a capital C :)
for clarity that's..
« Last Edit: December 30, 2011, 12:44:07 am by Mark Greaves (PCNetSpec) »
Offline alexishbob2
« Reply #10 on: December 30, 2011, 01:13:25 am »
I'm not entirely sure which bit you want so I'll just post the whole thing:
"ubuntu@ubuntu:~$ sudo lshw -C display
  *-display
       product: Turks XT [AMD Radeon HD 6600 Series]
       vendor: ATI Technologies Inc
       physical id: 0
       bus info: pci@0000:01:00.0
       version: 00
       width: 64 bits
       capabilities: pm pciexpress msi vga_controller bus_master cap_list rom
       configuration: driver=radeon latency=0
       resources: irq:44 memory:d0000000-dfffffff memory:fe620000-fe63ffff ioport:e000(size=256) memory:fe600000-fe61ffff"
« Reply #11 on: December 30, 2011, 01:39:47 am »
If you open a terminal and enter:
jockey-gtk
is anything listed under additional drivers ?
BTW, if there are any .. there's no point trying to activate them from the LiveCD .. I just want to know if there is anything listed.
« Last Edit: December 30, 2011, 01:41:29 am by Mark Greaves (PCNetSpec) »
Offline alexishbob2
« Reply #12 on: December 30, 2011, 01:48:15 am »
No, nothing comes up
« Reply #13 on: December 30, 2011, 01:51:59 am »
Do you have a USB stick larger than 1GB and do you know how to create a LiveUSB stick with persisence ?
I want to try installing the fglrx drivers, but this can't be done on a LiveCD .. and I'd rather not try it on your hard drive installation till it's tested first.
Offline alexishbob2
« Reply #14 on: December 30, 2011, 01:56:15 am »
I am actually using the LiveUSB at the moment, but I have no idea what you mean by the second bit
