Author Topic: Installing Sun Java JRE and browser plugin in PeppermintOS Two or Ubuntu 11.04  (Read 2237 times)
How to replace the IcedTea Java JRE and it's browser plugin with the Sun Java JRE and its browser pugin .. In PeppermintOS (Two) or Ubuntu 11.04.
The Sun version is more up-to-date, and IMHO quicker.
Open a terminal and run:
sudo add-apt-repository ppa:ferramroberto/java
sudo apt-get install sun-java6-jre sun-java6-plugin sun-java6-fonts
At this point the "Operating System Distributor License for Java" dialog will open .. use the Tab key to select <Ok> and hit enter.
Another dialog will open asking "Do you accept with the DLJ license terms ?" .. use the Tab key to select <Yes> and hit enter.
OK, (when that's finished) back in the terminal, run:
sudo update-alternatives --config java
You should see something like this:-
There are 2 choices for the alternative java (providing /usr/bin/java).
  Selection    Path                                      Priority   Status
* 0            /usr/lib/jvm/java-6-openjdk/jre/bin/java   1061      auto mode
  1            /usr/lib/jvm/java-6-openjdk/jre/bin/java   1061      manual mode
  2            /usr/lib/jvm/java-6-sun/jre/bin/java       63        manual mode
Hit 2 to select the  /usr/lib/jvm/java-6-sun/jre/bin/java and hit enter.
(use whatever number =  /usr/lib/jvm/java-6-sun/jre/bin/java)
Now run:
sudo update-alternatives --config mozilla-javaplugin.so
There are 2 choices for the alternative mozilla-javaplugin.so (providing /usr/lib/mozilla/plugins/libjavaplugin.so).
* 0            /usr/lib/jvm/java-6-openjdk/jre/lib/i386/IcedTeaPlugin.so   1061      auto mode
  1            /usr/lib/jvm/java-6-openjdk/jre/lib/i386/IcedTeaPlugin.so   1061      manual mode
  2            /usr/lib/jvm/java-6-sun/jre/lib/i386/libnpjp2.so            63        manual mode
Hit 2 to select the  /usr/lib/jvm/java-6-sun/jre/lib/i386/libnpjp2.so and hit enter.
(use whatever number =  /usr/lib/jvm/java-6-sun/jre/lib/i386/libnpjp2.so)
You can now go to this website:
http://www.java.com/en/download/help/testvm.xml
It should report:-
Vendor:  Sun Microsystems Inc
Version:  Java SE 6 Update 26
You can always use update-alternatives to change back if you wish.
« Last Edit: March 03, 2012, 02:47:24 pm by Mark Greaves (PCNetSpec) »
Offline banko
  • Full Member
Thanks for that Mark, done.
No problem :)
