Author Topic: How to install kernel 3.3.0 & NVIDIA 295.33 graphic card drivers.  (Read 2491 times)
Offline BkS
  • BkS Media Founder
    • BkS Media
I separated this into 2-parts. First part is for 32-bit users, second part for 64-bit users.
WARNING:   I'm not responsible if you install this and break your system. Kernel 3.3.0 is a non-stable kernel, and is highly experimental. For a stable release kernel use 3.2.12. You should remove any additional proprietary drivers before installing the kernel to be on the safe side.
This tutorial is for Debian-based distros only such as Ubuntu, Peppermint, Mint, etc, although it should be easily translated for Redhat distros.
For those updating to 3.3.0 and use NVIDIA drivers, you WILL have to update them to 295.33
Part 1 video:
32-bit Terminal commands:
cd /tmp && wget -O linux-headers-3.3.0-030300_3.3.0_all.deb http://goo.gl/B4JLM
sudo dpkg -i linux-headers-3.3.0-030300_3.3.0_all.deb
cd /tmp && wget -O  linux-headers-3.3.0-generic_i386.deb http://goo.gl/rzAJq
sudo dpkg -i linux-headers-3.3.0-generic_i386.deb
cd /tmp && wget -O linux-image-3.3.0-generic_i386.deb http://goo.gl/oAp4X
sudo dpkg -i linux-image-3.3.0-generic_i386.deb
Installing the NVIDIA 295.33 graphic card driver
sudo apt-add-repository ppa:ubuntu-x-swat/x-updates
sudo apt-get update && sudo apt-get install nvidia-current
REBOOT and when you log back in, type into terminal:
uname -r
Which should give the following output:
3.3.0-030300-generic
Part 2 video:
64-bit Terminal Commands:
cd ~
mkdir kernel-3.3
cd ~/kernel-3.3
wget -O linux-headers-3.3.0-generic_amd64.deb http://goo.gl/7wCbs
wget -O linux-image-3.3.0-generic_amd64.deb http://goo.gl/IuULZ
sudo dpkg -i *.deb
REBOOT, and you should be good.
To check your kernel version:
uname -r
You should get:
For help with errors, or any questions you have, post below and I'll answer them ASAP.
« Last Edit: March 31, 2012, 01:31:07 am by BkS »
