A little help with fstab (SOLVED)
Hi guys
Over the past few weeks I’ve been switching over from Freenas to Openmediavault on my NAS and it’s finally done and stable at last, I have 6 shares all visible in Gigolo, I would like to mount the shares in /mnt which requires editing /etc/fstab file something I’m not competent enough to do myself.
any help would be much appreciated
Many thanks
Okeydokey … what’s the output from:
sudo fdisk -l
sudo blkid
mount
and the current contents of
gedit /etc/fstab
graeme@Linux1 ~ $ sudo fdisk -l
[sudo] password for graeme:
Disk /dev/sda: 360.1 GB, 360080695296 bytes
255 heads, 63 sectors/track, 43777 cylinders, total 703282608 sectors
Disk identifier: 0x00000001
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1   *        2048   358106348   179052150+   7  HPFS/NTFS/exFAT
/dev/sda2       358107134   703281151   172587009    5  Extended
/dev/sda5       358107136   699107327   170500096   83  Linux
/dev/sda6       699109376   703281151     2085888   82  Linux swap / Solaris
graeme@Linux1 ~ $ sudo blkid
/dev/sda1: LABEL="Windows 7" UUID="02CAA59322478EE4" TYPE="ntfs"
/dev/sda5: UUID="034e3cfc-8511-446b-98eb-9e88283cf12a" TYPE="ext4"
/dev/sda6: UUID="50359b49-a810-460e-befa-9616af24bcba" TYPE="swap"
graeme@Linux1 ~ $ mount
/dev/sda5 on / type ext4 (rw,errors=remount-ro)
none on /sys/fs/cgroup type tmpfs (rw)
gvfsd-fuse on /run/user/graeme/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,user=graeme)
graeme@Linux1 ~ $
# /etc/fstab: static file system information. # # Use 'blkid' to print the universally unique identifier for a # device; this may be used with UUID= as a more robust way to name devices # that works even if disks are added and removed. See fstab(5). # # # / was on /dev/sda5 during installation UUID=034e3cfc-8511-446b-98eb-9e88283cf12a / ext4 errors=remount-ro 0 1 # swap was on /dev/sda6 during installation UUID=50359b49-a810-460e-befa-9616af24bcba none swap sw 0 0
Am I missing something … I can only see one HDD there.
Am I missing something .. I can only see one HDD there.
There is only one HDD, did you want that information from the PC or the NAS ?
Oh, hang on … you’re trying to mount remote shares ?
has the NAS got a static IP ?
Can you mount the shares through gigolo … THEN post the output from:
mount
you're trying to mount remote shares ?
Yes
Yes 192.168.2.50
Yes
graeme@Linux1 ~ $
OK, that didn’t give me what I wanted :o … were the shares mounted through gigolo when you ran “mount” to list the mounts ?
Do you know the path to the shares … such as
//192.168.2.50/share/video
//192.168.2.50/share/music
etc ?
If not, navigate to the share in file manager … then what does it say in the file manager address bar ?
and do the shares require login credentials ?
Doyou know the path to the shares .. such as
They are all samba shares, on 192.168.2.50, the share names are
family-tree
graeme
pat
multimedia
movies
backups
utilities
No they are all set for any user no password
just to be 100% sure … can you open file manager, and in the address bar enter:
smb://192.168.2.50/family-tree
and hit enter
smb://192.168.2.50/graeme
smb://192.168.2.50/pat
smb://192.168.2.50/multimedia
smb://192.168.2.50/movies
smb://192.168.2.50/backups
smb://192.168.2.50/utilities
were all the shares contents visible as expected ?
Yes
OK, first let’s create the mount points:
sudo mkdir -p /mnt/NAS
cd /mnt/NAS
sudo mkdir family-tree graeme pat multimedia movies backups utilities
close the terminal and confirm those directories exist in /mnt/NAS
or just post the output from:
ls -a /mnt
ok thats worked fine all the share folders are located at /mnt/NAS
Backup fstab … just in case:
sudo cp -v /etc/fstab /etc/fstab.backup
then we’ll mount the sharesss through ftsab one at a time.
ok that’s that done :slight_smile:
Open fstab for editing:
sudo gedit /etc/fstab
add a new line at the bottom that reads:-
# NAS shares
Then add another line below that that reads
//192.168.2.50/family-tree /mnt/NAS/family-tree cifs iocharset=utf8,dir_mode=0777,file_mode=0777 0 0
so the last 2 lines now read
# NAS shares
SAVE the file.
Open another terminal and run:
sudo mount -a
if any errors … post them here … if not, navigate to /mnt/NAS/family-tree
Can you see the contents as expected, and can you create a file or folder there ?
ok that worked I can see all the folders and create and delete a new folder
add a single new line at the bottom that reads:-
//192.168.2.50/graeme /mnt/NAS/graeme cifs iocharset=utf8,dir_mode=0777,file_mode=0777 0 0
SAVE the file.
sudo mount -a
if any errors … post them here … if not, navigate to /mnt/NAS/graeme
so far so good :slight_smile:
