A strange spreadsheet behaviour
In view of the esoteric posts in this section of the Forum, I hesitate to ask such an apparently simple question - but here goes.
I am fiddling with some *.XLS spreadsheets using LibreOffice for a club and have found an odd behaviour. The same thing happens if I create an *.ODS file, too.
If I create a column of numbers such as 1,2,3,4,5, highlight them then drag the handle down the column, the series is extended as expected.
If I create a column of formulae such as =B1,=B2,=B3,=B4,=B5, highlight them then drag the handle down the column, the series is extended as expected - displaying the contents of cells B1 to B5.
If I create a column of numbers such as 2,4,6,8, highlight them then drag the handle down the column, the series is extended as expected - in steps of 2.
If I create a column of formulae such as =B4,=B6,=B8, highlight them then drag the handle down the column, the result is:
=B4,=B6,=B8, =B7,=B9,=B11, =B10,=B12,=B14, =B13,=B15,=B17, etc.
Which is weird - and not what I want. I have tried it on a variety of machines using a Peppermint 3 laptop and a fresh install of Ubuntu 14 on a desktop.
Any ideas, anyone?
UPDATE Well, I [b]think[/b] I may have cracked it! The answer may be the use of indirect addressing. It means creating another column, but that's no hardship. UPDATE 2 Indirect addressing does the job. I found the info at https://wiki.openoffice.org/wiki/Documentation/OOo3_User_Guides/Calc_Guide/Address,_Indirect,_Offset,_Index.
Thanks for providing the solution to your own question Keith … I hadn’t a clue :o
Hi Mark.
I keep discovering interesting features of Calc but the hard bit is using the right search criteria to find them. Some of these commands are mind-bending to understand, but often worth the effort.
Thanks to this Forum (and your generous help) I am getting better at solving my own problems, which is why I haven’t been here for a while.
Cheers!
I’ve always been the “I can make it work, but then don’t ask me how to use it” type … if LO is broken, I can help you get it working, ask me ANYTHING about using it and I’m clueless.
So if I ever find the need to do a speadsheet we’ll be swapping places my mate :wink:
I wonder how many car mechanics there are out there that can’t drive :o
Keith,
Many thanks for your own question and answer. I am stumbling along at the moment with databases and spreadsheets.
I find LO excellent to work with and a friendly crowd too but I have to use MS as well as that is what the sheep in this particular fold have been using for donkey’s years. (where did all these animals come from ?).
I am much like you and keep discovering things about LO and try to make them useful. Best of luck.
take care
Don W
