AAO A110 : Usb/SDcard port problem [SOLVED]
Hello everyone ! :smiley:
Fristly, my nickname is Sezag, I’m 29 years old, from the north of France and a wonderfull Noob in Linux. :-
( sorry if my english is not really good )
I’ve found your website by cherching on google for an alternative OS for my Acer Aspire One (linux linpus lite) and Peppermint 4 seems really great.
But before installing that, i need to save all my pictures and the machine dont read any SD card or Usb key…
Can you help me please ?
Thanks a lot.
Sezag
Have you created a Peppermint 4 LiveUSB stick yet ?
Nearly forgot … welcome to the forum …
and your English beats the heck out of my (non existent) French :slight_smile:
I’m downloading Peppermint 4 right now.
Thank you :wink:
Well once you’ve created the LiveUSB stick, we can use that to access your files and copy them to a second USB stick or SD card.
Great news ^^
My download will finish in 20mn.
I come back when the LiveUSB stick is ready (in a half hour i think)
Okey dokey :slight_smile:
It’s ok the LiveUSB stick is ready.
and I have the http://linuxforums.org.uk/index.php?topic=11109.msg87330#msg87330 Open.
I’m listenning to you Master :smiley:
Sorry Sezag, I got called away for a while.
Are you able to boot from the LiveUSB and select “Try Peppermint” ? … do you end up at the Peppermint desktop ?
If so, if you click the “menu” buttton on the bottom panel (taskbar) and select “File Manager” … is the internal SSD/HDD listed in the left hand column ?
No problem. ^^
Yes ! All is perfect. I managed to recover my pictures and after a little test I’m installing peppermint4 with your tutorial.
Thanks a lot. :smiley:
You’re most welcome … and well done :slight_smile:
How can I write “Solved” on the title ?
Go to the FIRST posting in this topic, and click the “Modify” button and change:-
Subject: AAO A110 : Usb/SDcard port problem (SOLVED)
Then click the “Save” button :slight_smile:
Done ^^
Thanks :slight_smile:
