[ABANDONED] Need help creating a dual-boot laptop (Win10 & Kubuntu14.04)
Okay, set it to UEFI mode with secureboot disabled.
Windows should boot when you turn it on right ?
If so, boot to the Kubuntu LiveUSB by hitting F9 just after turning on the PC and selecting the USB stick as the boot device.
Once booted into a Kubuntu Live session from the USB stick, post the output from:
sudo fdisk -l
sudo blkid
efibootmgr -v
sudo fdisk -l
WARNING: GPT (GUID Partition Table) detected on ‘/dev/sda’! The util fdisk doesn’t support GPT. Use GNU Parted.
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
Disk identifier: 0x916d7395
/dev/sda1 1 1953525167 976762583+ ee GPT
Partition 1 does not start on physical sector boundary.
Disk /dev/sdb: 125.1 GB, 125061562368 bytes
255 heads, 63 sectors/track, 15204 cylinders, total 244260864 sectors
Disk identifier: 0x00034972
/dev/sdb1 * 64 244260863 122130400 c W95 FAT32 (LBA)
sudo blkid
/dev/loop0: LABEL=“Kubuntu 14.04.4 LTS amd64” TYPE=“iso9660”
/dev/loop1: TYPE=“squashfs”
/dev/sda1: UUID=“F278-E036” TYPE=“vfat”
/dev/sda3: LABEL=“Windows” UUID=“B0DE0ED6DE0E94AE” TYPE=“ntfs”
/dev/sda4: LABEL=“Windows RE tools” UUID=“48520F8A520F7BC6” TYPE=“ntfs”
/dev/sda5: LABEL=“RECOVERY” UUID=“9CA0BFDCA0BFBADA” TYPE=“ntfs”
/dev/sda6: UUID=“3bef93e3-009e-4af0-acc2-f2aaf0860c17” TYPE=“ext4”
/dev/sda7: UUID=“bd7838f8-8ac0-456a-99bf-0a001eb445e6” TYPE=“swap”
/dev/sdb1: LABEL=“MULTISYSTEM” UUID=“70C6-7CFF” TYPE=“vfat”
efibootmgr -v
The program ‘efibootmgr’ is currently not installed. You can install it by typing:
sudo apt-get install efibootmgr
Reading package lists… Done
Building dependency tree
The following NEW packages will be installed:
efibootmgr
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/28.4 kB of archives.
After this operation, 103 kB of additional disk space will be used.
Selecting previously unselected package efibootmgr.
(Reading database … 107288 files and directories currently installed.)
Preparing to unpack …/efibootmgr_0.5.4-7ubuntu1.2_amd64.deb …
Unpacking efibootmgr (0.5.4-7ubuntu1.2) …
Processing triggers for man-db (2.6.7.1-1ubuntu1) …
Setting up efibootmgr (0.5.4-7ubuntu1.2) …
efibootmgr -v
Fatal: Couldn’t open either sysfs or procfs directories for accessing EFI variables.
Try ‘modprobe efivars’ as root.
Hey Mark, You there?
I posted what you requested in my last post.
Hope you can help.
Thanks
Pete
Try this, boot to Kubuntu 14.04.4 64bit from your LiveUSB (in UEFI mode), open a terminal and run these commands in sequence:
sudo mount /dev/sda6 /mnt
sudo mount /dev/sda1 /mnt/boot/efi
for i in /dev /dev/pts /proc /sys /run; do sudo mount -B $i /mnt$i; done
sudo chroot /mnt
grub-install /dev/sda --target=x86_64-efi
update-grub
then hit Ctrl+D to exit the chroot environment. (the prompt should change back to $)
Close the terminal and shut down the PC
Remove the LiveUSB
Turn ON the PC
did it boot ?
Mark, I did all your instructions and it still just booted to the GRUB Terminal screen.
Are you able to boot to Windows ?
If so, how ?
I’ve decided to wipe Window$ and do a new install of Kubuntu.
I have grown sick of seeing ‘(Not Working)’ at the top of the window of the program I was currently using and having to run clean up loads of times.
