[ABANDONED] Problem installing Google Drive [UPGRADED OS]
I recently discovered I could access my Google Drive from Dolphin when I found THIS video.
I tried following the instructions using Terminal but it would not install
 sudo apt-get kacounts-providers kio-gdrive
I found that kaccounts-providers was already installed and kio-gdrive would not install.
I then thought of trying to install using synaptic and that’s when I found that kio-gdrive was not in the repo, so I did a little more digging and found THIS site where I found the following commands,
sudo apt install gnome-control-center gnome-online-accounts
I decided to use synaptic again, but I encountered yet more problems…
unity-scope-gdrive has broken dependencies.
account-plugin-google wants to be installed and when I click to continue and install, I get;
http://i.imgur.com/9my5iIK.png
So what was the ACTUAL terminal output from:
E: Invalid operation kaccounts-providers
I did a typo, there should have been two 'c’s in ‘accounts’
…But, shouldn’t I enter
first, so it can pull all the needed info?
I’ve had a look in synaptic and I have got kaccounts-providers already installed.
http://i.imgur.com/4V0cj7hl.png
So what’s the problem now ?
Broken packages, unity-scope-drive
I select it for re-installation, it requires account-plugin-google
I start the installation process then I get the error I posted earlier ‘E:Internal Error, no file name for unity-scope-gdrive:amd64’
I have just thought, why not try installation again, where this time I got;
http://i.imgur.com/6W1QYG8.png
It would be REALLY helpful you’d stop with the screenshots of error output, I can’t copy/paste text from an image.
You can’t have both of these installed at the same time
kaccounts-providers
So you’re going to need to decide if you want to go with the unity scope method or kio-gdrive option … then uninstall the other.
Start with
sudo apt-get remove account-plugin-google kaccounts-providers
but be SURE to check what else will be removed before accepting.
Then choose one or the other methods.
