about Proper installation of linux kubuntu 64 bit
first
What is more preferable?
version of LTS or the new?
http://www.kubuntu.org/getkubuntu/
Second thing
I would like to know how exactly install this via usb stick, when Meanwhile I’m interested To stay with current linux mint also.& To stay with os of windows.
thank
Does your PC have UEFI or BIOS ?
bios
I edited my previous post
Hi rami
What is more preferable? version of LTS or the new?
That really depends on you the main difference is that 14.04 is an LTS release which stands for Long Term Support it was released in April 2014 with 5 years support so will continue to receive updates until April 2019, 15.10 is a development release and will only receive updates until July 2016,
So with the 15.10 release although you will get the latest kernel and software it will only be supported for a short time before you have to upgrade again and may be more prone to bugs on the other hand 14.04 is supported much longer but will have a slightly older kernel and software may be older versions in some cases but may probably be more stable
so it’s a question of stability v cutting edge personally I’d go for 14.04 but it’s your choice
Good luck
You’d have to decide if the extended support of the LTS, or the newer kernel and software of the more recent version suits your usage best.
As long as you’re not on a UEFI system, Kubuntu should offer to install “alongside” your current OS’s, then offer you a screen to adjust how much space you want to give the new OS and where to steal it from.
Installing from a USB stick should be as easy as using the “USB Image Writer” in Mint to write the Kubuntu ISO image to a USB stick … booting to that USB stick … then clicking the “Install Kubuntu” icon on the live session desktop.
so i ask to try to install the kubuntu of LTS
but
if later i’ll ask to install the new version of kubuntu so how know exactly that Delete only LTS of kubuntu?
how much space It is recommended to give to the LTS of kubuntu version 14.04?
in os linux mint mate 17.2 of 64 bit, how exactly Come to the USB Image Writer? & how exactly use it?
& how exactly to use in software of GParted in linux mint? to make Partition to the os of lunux kubuntu version 14.04.
& if need so how exactly to format the usb stick?
thank
if later i'll ask to install the new version of kubuntu so how know exactly that Delete only LTS of kubuntu?
You would do that in a partition manager such as gparted which will allow to delete the partition along with the OS you no longer want leaving unallocated space where you would then install the new version on to
hope I’ve explained that ok :slight_smile:
about to this
“if later i’ll ask to install the new version of kubuntu so how know exactly that Delete only LTS of kubuntu”
This is when the Meanwhile, i ask to stay with the current linux mint.
in the software of GParted no write in Every partition what Exactly it’s contain, so what to do to delete the only LTS of kubuntu?
thank
in the software of GParted no write in Every partition what Exactly it's contain, so what to do to delete the only LTS of kubuntu? thank
That’s a good question
Gparted will list each partition with a number ie sdb1 or sdb2 etc so you would identify the partition you want to uninstall by it’s number before you start , there are various ways to do that,
You could identify the partition you’re currently running by opening in the terminal
inxi -l
from the screenshot you’ll see my drive is listed as /dev/sdb5
http://i.imgur.com/z0r6Tgv.png
but mine it’s More than 1 Identification of /dev/
here
rami@rami-System-Product-Name ~ $ inxi -l
Partition: ID: / size: 19G used: 7.9G (45%) fs: ext4 dev: /dev/sda6 label: N/A
ID: swap-1 size: 2.15GB used: 0.09GB (4%) fs: swap dev: /dev/sda7 label: N/A
So how here i know where exactly it’s the Identification of the my Current os of linux?
Which partition are you trying to identify ? … the kubuntu LTS partition ?
if so, boot into Kubuntu LTS, and post the output from:
mount
sudo fdisk -l
sudo blkid
and the contents of
kate /etc/fstab
(if kate isn’t the default text editor in Kubuntu you’ll need to adjust that last command)
Maybe this will help guys. rami has a Dual Boot with XP and Linux Mint Mate at the end of his Drive on that 20GB Partition. He want’s to install Kubuntu, and for his needs I think it is clear that he should use the LTS.
Hi NastyCodes and welcome to the forum :slight_smile:
Firstly can I ask that you not attach document to posts without them having been specifically asked for by admin … there’s limited space on the servers so we’d prefer to keep it only for when there’s no other/better solution :wink:
Can you either host the file somewhere else such as pastebin (or somewhere similar) and post a link, or place any text “inline” in the post so it’s indexable and future searchers may benefit from it in the future.
Is that statement because you know him ? … what are those needs ? … personally I was thinking of suggesting he waited until 16.04, and awaiting to hear if he’s in a hurry or not ?
First I am interested to identify the partition of the my current os linux mint.
If I’ll a prefer later to remove this without delete something else.
thank
“Is that statement because you know him ?”
i thinking that i know this user name from Other forum that not good for me to be there.
But not his first name.
i thinking maybe is nuna? or pcpunk? or al1000? or cat1092? or nikcau?
“his Drive on that 20GB Partition”
More than 20 GB, 20 GB only to linux, When I’m not sure that size is Really good for this linux, the 20 GB These Because that offered me this.
Sure, I tried to Remove it but could not. Not familiar with pastebin usage so will look into that.
So it would have been fine to “Paste” it into the post?
Yes, because I know him…I’ll let him explain to you…That is a good idea, I’ll stay out of it.
Do members always have to use the CAPTCHA is it only for the noobs?
@rami: If you or the staff needs your “gparted” screenshot just say so and I will post it. I didn’t realize that the Attachment I provided did not show all that is on your Drive.
@NastyCodes
I thought the forum settings for the catcha were only for first post approval … are you still being required to enter it ?
@rami
Would it make more sense to wait until April next year for the release of the next LTS edition (16.04), or do you want to continue and install the last one (14.04) ?
“Would it make more sense to wait until April next year for the release of the next LTS edition (16.04), or do you want to continue and install the last one (14.04) ?”
Meanwhile installed the 14.04 & Meanwhile i ask to stay linx mint also.and os windows also.
so how exactly i identify the partition of the my current os linux mint?
Boot into Mint, then open a terminal and post back here the output from running the following commands:
mount
sudo fdisk -l
sudo blkid
and the contents of
kate /etc/fstab
rami@rami-System-Product-Name ~ $ mount
/dev/sda6 on / type ext4 (rw,errors=remount-ro)
none on /sys/fs/cgroup type tmpfs (rw)
none on /sys/fs/pstore type pstore (rw)
systemd on /sys/fs/cgroup/systemd type cgroup (rw,noexec,nosuid,nodev,none,name=systemd)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,user=rami)
/dev/sdb1 on /media/rami/UUI type vfat (rw,nosuid,nodev,uid=1000,gid=1000,shortname=mixed,dmask=0077,utf8=1,showexec,flush,uhelper=udisks2)
rami@rami-System-Product-Name ~ $ sudo fdisk -l
[sudo] password for rami:
Disk /dev/sda: 320.1 GB, 320072933376 bytes
86 heads, 15 sectors/track, 484606 cylinders, total 625142448 sectors
Disk identifier: 0x00000001
/dev/sda1 * 15 268433519 134216752+ 7 HPFS/NTFS/exFAT
/dev/sda2 268433533 625141759 178354113+ f W95 Ext’d (LBA)
/dev/sda5 268433535 581520389 156543427+ 7 HPFS/NTFS/exFAT
/dev/sda6 581521408 620949503 19714048 83 Linux
/dev/sda7 620951552 625141759 2095104 82 Linux swap / Solaris
Disk /dev/sdb: 16.0 GB, 16025387008 bytes
255 heads, 63 sectors/track, 1948 cylinders, total 31299584 sectors
Disk identifier: 0x1e582bf8
/dev/sdb1 * 63 31294619 15647278+ c W95 FAT32 (LBA)
rami@rami-System-Product-Name ~ $ sudo blkid
/dev/sda1: LABEL=“windows” UUID=“FCAC9EE6AC9E9AAA” TYPE=“ntfs”
/dev/sda5: UUID=“01D0E78175042DF0” TYPE=“ntfs”
/dev/sda6: UUID=“426bd867-5ea7-4ae3-ab0e-17e5b849f289” TYPE=“ext4”
/dev/sda7: UUID=“510e371c-abd6-44f2-8db5-fa73dee7e9ee” TYPE=“swap”
/dev/sdb1: LABEL=“UUI” UUID=“24E2-054A” TYPE=“vfat”
rami@rami-System-Product-Name ~ $ kate /etc/fstab
QDBusConnection: session D-Bus connection created before QCoreApplication. Application may misbehave.
kate(19751)/kdeui (KIconLoader): Error: standard icon theme “oxygen” not found!
kate(19751)/kate-filetree KateFileTreePluginView::KateFileTreePluginView: BEGIN: mw: Kate::MainWindow(0x88f19e0)
kate(19751)/kate-filetree ProxyItem::ProxyItem: ProxyItem(0x8ac7278,0x0,-1,QObject(0x0) ,“m_root”)
kate(19751)/kate-filetree ProxyItem::ProxyItem: ProxyItem(0x8ac87e0,0x0,-1,QObject(0x0) ,“Untitled”)
kate(19751)/kate-filetree KateFileTreeModel::documentOpened: before add: ProxyItem(0x8ac87e0,0x0,-1,KateDocument(0x88fbd00) , “Untitled” )
kate(19751)/kate-filetree KateFileTreeModel::setupIcon: BEGIN!
kate(19751)/kate-filetree KateFileTreeModel::setupIcon: END!
kate(19751)/kate-filetree KateFileTreeModel::handleInsert: BEGIN!
kate(19751)/kate-filetree KateFileTreeModel::handleInsert: empty item
kate(19751)/kate-filetree ProxyItem::addChild: added ProxyItem(0x8ac87e0,0x8ac7278,0,KateDocument(0x88fbd00) , “Untitled” ) to ProxyItemDir(0x8ac7278,0x0,-1,“m_root”, children:1)
kate(19751)/kate-filetree KateFileTreeModel::documentOpened: after add: ProxyItem(0x8ac87e0,0x8ac7278,0,KateDocument(0x88fbd00) , “Untitled” )
kate(19751)/kate-filetree KateFileTreeProxyModel::KateFileTreeProxyModel: BEGIN!
kate(19751)/kate-filetree KateFileTreePluginView::setListMode: BEGIN
kate(19751)/kate-filetree KateFileTreePluginView::setListMode: treeMode
kate(19751)/kate-filetree KateFileTreePluginView::setListMode: END
kate(19751)/kate-filetree KateFileTreePluginView::viewChanged: BEGIN!
kate(19751)/kate-filetree KateFileTreeProxyModel::docIndex: !
kate(19751)/kate-filetree KateFileTreeModel::docIndex: BEGIN!
kate(19751)/kate-filetree KateFileTreeModel::docIndex: END!
kate(19751)/kate-filetree KateFileTreePluginView::viewChanged: selected doc= KateDocument(0x88fbd00) QModelIndex(0,0,0x8997778,KateFileTreeProxyModel(0x8aceda8) )
kate(19751)/kate-filetree KateFileTreePluginView::viewChanged: display= “Untitled”
kate(19751)/kate-filetree KateFileTreeModel::documentActivated: BEGIN!
kate(19751)/kate-filetree KateFileTreeModel::documentActivated: adding viewHistory ProxyItem(0x8ac87e0,0x8ac7278,0,KateDocument(0x88fbd00) , “Untitled” )
kate(19751)/kate-filetree KateFileTreeModel::updateBackgrounds: BEGIN!
kate(19751)/kate-filetree KateFileTreeModel::updateBackgrounds: m_editHistory contains 0 elements
kate(19751)/kate-filetree KateFileTreeModel::updateBackgrounds: END!
kate(19751)/kate-filetree KateFileTreeModel::documentActivated: END!
kate(19751)/kate-filetree KateFileTree::slotCurrentChanged: current: QModelIndex(0,0,0x8997778,KateFileTreeProxyModel(0x8aceda8) ) previous: QModelIndex(-1,-1,0x0,QObject(0x0) )
kate(19751)/kate-filetree KateFileTree::slotCurrentChanged: got doc, setting prev: QModelIndex(0,0,0x8997778,KateFileTreeProxyModel(0x8aceda8) )
kate(19751)/kate-filetree KateFileTreePluginView::viewChanged: END!
kate(19751)/kate-filetree KateFileTreeModel::documentNameChanged: BEGIN!
kate(19751)/kate-filetree KateFileTreeModel::documentNameChanged: change to unnamed item
kate(19751)/kate-filetree KateFileTreeModel::documentNameChanged: ProxyItem(0x8ac87e0,0x8ac7278,0,KateDocument(0x88fbd00) , “Untitled” )
kate(19751)/kate-filetree KateFileTreeModel::documentNameChanged: “Untitled” → “Untitled”
kate(19751)/kate-filetree KateFileTreeModel::documentNameChanged: removing brush ProxyItem(0x8ac87e0,0x8ac7278,0,KateDocument(0x88fbd00) , “Untitled” )
kate(19751)/kate-filetree KateFileTreeModel::documentNameChanged: removing/replacing view history ProxyItem(0x8ac87e0,0x8ac7278,0,KateDocument(0x88fbd00) , “Untitled” )
kate(19751)/kate-filetree KateFileTreeModel::handleNameChange: BEGIN!
kate(19751)/kate-filetree KateFileTreeModel::handleNameChange: bogus name change
kate(19751)/kate-filetree KateFileTreeModel::documentNameChanged: END!
kate(19751)/kate-filetree KateFileTreeModel::documentNameChanged: “Untitled” → “/etc/fstab”
kate(19751)/kate-filetree KateFileTreeModel::handleNameChange: removing ProxyItem(0x8ac87e0,0x8ac7278,0,KateDocument(0x88fbd00) , “/etc/fstab” ) from ProxyItemDir(0x8ac7278,0x0,-1,“m_root”, children:1)
kate(19751)/kate-filetree KateFileTree::slotCurrentChanged: current: QModelIndex(-1,-1,0x0,QObject(0x0) ) previous: QModelIndex(0,0,0x8997778,KateFileTreeProxyModel(0x8aceda8) )
kate(19751)/kate-filetree ProxyItem::remChild: remove ProxyItem(0x8ac87e0,0x8ac7278,0,KateDocument(0x88fbd00) , “/etc/fstab” ) from ProxyItemDir(0x8ac7278,0x0,-1,“m_root”, children:1)
kate(19751)/kate-filetree KateFileTreeModel::handleEmptyParents: BEGIN!
kate(19751)/kate-filetree KateFileTreeModel::handleEmptyParents: parent ProxyItemDir(0x8ac7278,0x0,-1,“m_root”, children:0) grandparentProxyItemDir(0x0)
kate(19751)/kate-filetree KateFileTreeModel::handleNameChange: inserting ProxyItem(0x8ac87e0,0x0,0,KateDocument(0x88fbd00) , “/etc/fstab” )
kate(19751)/kate-filetree KateFileTreeModel::handleInsert: creating a new root
kate(19751)/kate-filetree ProxyItem::ProxyItem: ProxyItem(0x8cc7898,0x0,-1,QObject(0x0) ,“/etc”)
kate(19751)/kate-filetree KateFileTreeModel::handleInsert: add ProxyItemDir(0x8cc7898,0x0,-1,“/etc”, children:0) to m_root
kate(19751)/kate-filetree ProxyItem::addChild: added ProxyItem(0x8cc7898,0x8ac7278,0,QObject(0x0) ,“/etc”) toProxyItemDir(0x8ac7278,0x0,-1,“m_root”, children:1)
kate(19751)/kate-filetree KateFileTreeModel::handleInsert: attempting to merge some existing roots
kate(19751)/kate-filetree KateFileTreeModel::handleInsert: adding ProxyItem(0x8ac87e0,0x0,0,KateDocument(0x88fbd00) , “/etc/fstab” ) to ProxyItemDir(0x8cc7898,0x8ac7278,0,“/etc”, children:0)
kate(19751)/kate-filetree ProxyItem::addChild: added ProxyItem(0x8ac87e0,0x8cc7898,0,KateDocument(0x88fbd00) , “/etc/fstab” ) to ProxyItemDir(0x8cc7898,0x8ac7278,0,“/etc”, children:1)
kate(19751)/kate-filetree KateFileTreeModel::handleInsert: END!
kate(19751)/kate-filetree KateFileTreeModel::handleNameChange: END!
kate(19751)/kate-filetree KateFileTreePluginView::viewChanged: selected doc= KateDocument(0x88fbd00) QModelIndex(0,0,0x8cc0470,KateFileTreeProxyModel(0x8aceda8) )
kate(19751)/kate-filetree KateFileTreePluginView::viewChanged: display= “fstab”
kate(19751)/kate-filetree KateFileTreeModel::documentActivated: adding viewHistory ProxyItem(0x8ac87e0,0x8cc7898,0,KateDocument(0x88fbd00) , “/etc/fstab” )
kate(19751)/kate-filetree KateFileTree::slotCurrentChanged: current: QModelIndex(0,0,0x8cc0470,KateFileTreeProxyModel(0x8aceda8) ) previous: QModelIndex(-1,-1,0x0,QObject(0x0) )
kate(19751)/kate-filetree KateFileTree::slotCurrentChanged: got doc, setting prev: QModelIndex(0,0,0x8cc0470,KateFileTreeProxyModel(0x8aceda8) )
kate(19751)/kate-filetree KateFileTreeModel::documentNameChanged: ProxyItem(0x8ac87e0,0x8cc7898,0,KateDocument(0x88fbd00) , “/etc/fstab” )
kate(19751)/kate-filetree KateFileTreeModel::documentNameChanged: “fstab” → “/etc/fstab”
kate(19751)/kate-filetree KateFileTreeModel::documentNameChanged: removing brush ProxyItem(0x8ac87e0,0x8cc7898,0,KateDocument(0x88fbd00) , “/etc/fstab” )
kate(19751)/kate-filetree KateFileTreeModel::documentNameChanged: removing/replacing view history ProxyItem(0x8ac87e0,0x8cc7898,0,KateDocument(0x88fbd00) , “/etc/fstab” )
kate(19751)/kate-filetree KateFileTreePluginSettings::save: save config!
