are novel (suse ) in trouble
i only ask as this was tweeted to my private account
"Do you have expertise in several Linux kernel areas? Come work for " #SUSE http://bit.ly/VOgzP9
if there not they will be if i work there :-[ :-[ :-[
YaST and zypper no thank you very much and thats before kernal work
Don’t know … don’t care … don’t like/use SUSE :slight_smile:
What makes you think them advertising a kernel dev job suggest they are in trouble ? … I would have though when they are NOT offering jobs would be a better indicator ???
just the mess they are having with ARM at the moment i dont like suse/opensuse becase of yast mainly
I thought they’d finished openSUSE 12.2 for ARM ???
