Auto wifi after resume
This is not strictly a peppermint problem as it has happened before on linux mint17 cinnamon.
http://linuxforums.org.uk/index.php?topic=11845.msg94633#msg94633 hope the link works.
I think its a conflict with my hardware.
when I resume by opening lid, a box requesting wi fi authorisation pops up, if I click on connect the box just keeps reappearing.
If I click on cancel then click on the button on panel, then click on my wifi connection it connects.
Because I want to keep pep 5 until the next LTS, it would be good if it could be sorted.
thanks in advance
When it resumes from suspend and asks for authorisatioon, leave it, just open a terminal and run:
nmcli nm enable false ; nmcli nm enable true
does wifi automatically authenticate ?
Effectively that’s disabling networking, then re-enabling it again.
If that works … maybe we can script it.
Hi Mark.
Yes that works :slight_smile:
Let’s try this…
Open a terminal and run:
sudo touch /etc/pm/sleep.d/nm-resume
sudo chmod +x /etc/pm/sleep.d/nm-resume
sudo gedit /etc/pm/sleep.d/nm-resume
When a BLANK file opens, make it read:-
#!/bin/sh
# This script gets NetworkManager out of suspend.
case $1 in
     suspend|suspend_hybrid|hibernate)
    # Nothing needs to go here.
     resume|thaw)
    nmcli nm sleep false
esac
SAVE the file … test resume from suspend
sorry for the delay (us old ones have to go to bed early) :wink:
copied and pasted your instructions (twice), but did not work.
after getting so close to a solution,
is it possible anyone knows how to proceed, because this OS is the so far the best I’ve used and it seems a shame one small problem is spoiling the experience.
Thanks in anticipation.
Can you post the result of:
ls /etc/pm/sleep.d
keith@keith-Lenovo-G550 ~ $ ls /etc/pm/sleep.d
10_grub-common nm-resume nm-resume.sh
10_unattended-upgrades-hibernate nm-resume~ nm-resume.sh~
thanks
It appears to be ignoring the syntax that used to work … I’m still looking for a way to run commands upon resume.
Meanwhile, get rid of all those nm-resume files so they don’t interfere with anything we try in the future
cd /etc/pm/sleep.d
sudo rm -v nm-resume*
I’ll get back to this if I find anything
OK
