Aw, Snap! (SOLVED)
Hi Guys
I’ve just re-installed PM4 and I’m having a problem with Chromium, everytime I try to access a website or even a search engine I get a grey screen with Aw, Snap! even clicking on suggestions leads to the same thing, I tried changing the search engine to Duck Duck Go that opens up search engines but wouldn’t open any webpage Google Search wouldn’t as much as open a webpage, I haven’t installed any plugins and I disabled a few Extensions but that’s made no difference, I’m able to access this site by typing the address in the address bar
many thanks
Ok panic over, problem solved by a system update
Yeah, someone else emailed me about that … system update fixed it for him to :slight_smile:
